  • Globe Motors D36-B10A-05W2-000 92 x 25mm Fan 24 VDC 0.09A Lock Rotor Protected with 12" Lead Wires 2400 RPM
BUYOUT Globe Motors D36-B10A-05W2-000 92 x 25mm Fan 24 VDC 0.09A Lock Rotor Protected with 12" Lead Wires 2400 RPM
Factory BuyoutsPart # 259-2024
Model: D36-B10A-05W2-000
2 Questions, 3 Answers or
Extend the life of your electronics economically by using this 92 mm x 25 mm 24 VDC cooling fan.
  • Protect amplifiers, power supplies and heat generating components
  • Great for projects and replacement
  • Low power consumption and high air-flow
BUYOUT $1.97
MSRP: $15.00
Save $13.03 (87%)
539 In Stock
We'll send you an email when Globe Motors D36-B10A-05W2-000 92 x 25mm Fan 24 VDC 0.09A Lock Rotor Protected with 12" Lead Wires 2400 RPM is back in stock or available for preorder.
Cooling is the low-cost, added defense to protect your electronics project and investment. Amplifiers, power supplies and many other heat producing devices will work harder and last longer when the heat produced is moved away and replaced by cooler air. These economical cooling fans are a great accessory for your project. Low power consumption and high air flow volume makes these fans ideal for any project. This fan comes with 12" leads to quickly solder into place.
Specifications: • Operating voltage: 24 VDC • Power: 2.16 watts • Speed: 2400 RPM • Lead wire: 12" • Dimensions (W x H x D): 92 x 92 x 25 mm.
BrandFactory Buyouts
ModelD36-B10A-05W2-000
Part Number259-2024
UPC848864065373
Weight0.3
Operating Voltage24 VDCV
Size92
