  • Gemini PA-SYS15 Dual Speaker PA Package w/ Speaker Stands and Microphone
CLEARANCE Gemini PA-SYS15 Dual Speaker PA Package w/ Speaker Stands and Microphone
GeminiPart # 235-182
Model: PA-SYS15
The Gemini PA‑SYS15 is a complete PA package with one active and one passive 15″ speaker, speaker stands, and microphone, offering 2,000 W peak Class‑AB power and an integrated media player for mobile or event use.
  • 15″ LF woofer and 1″ titanium HF driver deliver full-range sound from 30 Hz to 20 kHz
  • Includes wired mic and mic input with independent volume control
  • Bluetooth, USB, SD, and FM playback provide versatile media source options
  • Built-in EQ lets you shape sound for different events without external gear
  • Mix‑Out jack enables connection to external mixers or systems
  • Collapsible tripod stands included for easy setup and portability
  • Rugged ABS cabinet with top and side handles built to withstand live use
Gemini ES-210MXBLU-St 10" Portable PA System Pair w/ Speaker Stands
Price: $369.95Part # 235-143
See all items in PA Speaker Systems
We'll send you an email when Gemini PA-SYS15 Dual Speaker PA Package w/ Speaker Stands and Microphone is back in stock or available for preorder.
Bluetooth Connectivity
Stream music wirelessly from any Bluetooth device with a range of up to 30 feet.
2000-Watts Peak Power Total
One speaker features a built-in Class AB amplifier, while the other is passive. Both are equipped with a 15" LF woofer and a 2" voice coil.
Built-in Media Player
Play MP3, WAV, and FLAC audio files directly from a USB drive or SD card.
Microphone Included
Includes a complete speaker package with one wired microphone for clear and reliable sound amplification.
Elevate your Sound
Provides sturdy support and extends up to 74 inches in height, ensuring your sound projects loud and clear.
Powerful Pair
Connect the passive speaker to the active powered speaker using the included cables for seamless power and audio transmission.
Roll it the Easy Way
Both speakers feature built-in wheels for easy transport, removing the hassle of lifting or carrying.
Limitless Possibilities
Dedicated input channels with individual gain controls, plus XLR, 1/4", and RCA inputs for mic and line sources.
Take Charge and Control
Comprehensive rear panel includes mixer, media player, volume controls, and EQ for an all-in-one solution.
Empowering your Sound
Bring vibrant energy to any community event with the PA-SYS15, delivering captivating sound that enhances every gathering. Celebrate, connect, and engage with ease, making sure your message and music are heard. Let the powerful sound waves create lasting memories and foster a true sense of community spirit.
Fuel your Passion
Feel the ground shake as the PA-SYS15 releases a powerful wave of sound, filling the field with cheers and thunderous applause. From hard-hitting tackles to stunning goals, every moment is amplified by crystal-clear audio that blankets the entire venue. With its outstanding sound quality, the PA-SYS15 transforms every seat into a front-row experience, capturing the full excitement of the event.
Loud and Clear
Elevate the big day with the perfect sound solution. The PA-SYS15 delivers outstanding audio quality and wide coverage, making it ideal for special events. Whether it’s heartfelt speeches or celebratory music, this dual PA speaker system ensures every moment of the graduation ceremony is heard with clarity and elegance.
Expand your Horizons
The PA-SYS15 is the ultimate audio solution tailored for corporate events, seminars, and conferences. It delivers superior performance and precise sound reproduction, ensuring your message is conveyed with impact and clarity. Its sleek design and durable build make it a perfect fit for professional settings, effortlessly complementing any atmosphere.
  • Active/Passive: 1st speaker - Active, 2nd speaker - Passive: Ahoy there, music lovers! The Gemini PA system is a dynamic duo with an active and a passive speaker. What's the difference, you ask? The active speaker has its amplifier built-in. Perfect for a band on the go or a spontaneous DJ set. No extra equipment needed, making your sound system setup a breeze!
  • Amplifier Type: Class AB: With a Class AB amplifier, you get the best of both worlds. This means you'll have the efficiency of a Class B amplifier and the high-quality sound of a Class A. Sounds like a harmonious marriage, doesn't it? Perfect for those live events where every note matters.
  • LF/HF Driver Size: 2 x 15“ : A 2 x 15" LF driver and a 2 x 1" HF driver? We're talking deep bass and crystal clear highs, perfect for those thumping beats or soothing vocals. With these drivers, your sound will have the balance it deserves, making your PA system the belle of the ball at any gig.
  • Total Peak Power: 2000W: Power to the people, right? With a staggering 2000W of peak power, your PA system will be as loud as a roaring lion or as soft as a purring kitten. With this much power, your sound will reach every corner of the room, ensuring no one misses a beat.
  • Inputs / Outputs: 2 x XLR, RCA, 1/8” / XLR Mix Output, AMP Out (to passive speaker) : Whether you're rocking out with electric guitars or spinning tracks on a turntable, Gemini has you covered. With 2 x XLR, RCA, 1/8" inputs and XLR Mix Output, AMP Out, this system's versatility lets you plug and play with ease. It's a complete package for any DJ or band.
  • Media Player: USB/SD, Bluetooth, FM+Control: No vinyl? No problem! The in-built media player has USB/SD, Bluetooth, and even FM radio capabilities. You can keep the crowd entertained in any situation, making you the life of the party, even if your band hasn't shown up yet.
  • Bluetooth: This little PA gem comes with a TWS link, a true wireless stereo. This means you can link two Bluetooth speakers, and they'll play simultaneously. Imagine that – a complete sound experience from compact equipment!
  • Frequency Response: 30Hz-20kHz: The Gemini offers a frequency response from 30Hz-20kHz. That's lower than an elephant's trumpet and higher than a bat's squeak! Perfect for capturing every sound from your mixer, whether you're a professional DJ or an emerging live band.
  • Sensitivity & Impedance: 96db 8Ω: With a sensitivity of 96db and an impedance of 8Ω, this professional system will react swiftly to your sound's intensity changes. The result? A finely-tuned performance that'll have your audience thinking they're listening to a studio recording.
  • Enclosure Material: With an ABS impact-resistant nylon fiber cabinet, this PA system isn't just about great sound; it's tough, too! It'll stand up to the rigors of live events, from band gigs to DJ sets, like a knight in shining armor.
  • Mounting Options: Speaker Stand 1 3/8" Diameter Mount: The PA system offers a speaker stand mount with a 1 3/8" diameter. So, you can place your speakers on stands and get the sound pumping right at the audience level. A perfect solution for all those portable parties, events, and concerts.
  • Power Adapter: IEC – AC 115/230V 50Hz-60Hz: The power adapter has IEC – AC 115/230V 50Hz-60Hz. You can plug it in just about anywhere and be the sonic superhero you're destined to be! Great for international tours or home-based events.
  • Power Fuse: 3.15A: Pop, fizz, boom! Nope, we're not talking about a soda can or firecrackers, we're talking about power surges. But don't fret! This PA system comes with a 3.15A fuse for protecting your equipment against electrical gremlins. It's like having a loyal guard dog for your PA system, keeping it safe so you can focus on creating amazing sounds!
  • Dimensions: 13.7" x 26.93" x 16.81"
  • Weight: 57.3 lbs
BrandGemini
ModelPA-SYS15
Part Number235-182
UPC747705006356
Weight75.15
Configuration2-way
Speaker TypeBluetooth
Woofer Size15"
