  • Gemini GHRK-400-PR Outdoor Rock Speaker Pair w/ Bluetooth
GeminiPart # 235-101
Model: GHRK-400-PR
The Gemini Sound GHRK-400-PR is a pair of wireless Bluetooth rock speakers designed to blend seamlessly into outdoor environments while delivering a robust performance. Ideal for patios, gardens, and poolside gatherings, their natural rock-like appearance complements outdoor aesthetics, providing both style and functionality.
  • IPX5 weatherproof rating ensures durability in various outdoor conditions
  • True Wireless Stereo (TWS) technology for immersive stereo sound
  • Built-in 2000mAh rechargeable batteries offer up to 10 hours of playtime
  • 4" full-range drivers deliver 20W peak power each
  • Natural rock design blends seamlessly into outdoor settings​
  • Aerospace grade composite provides stiffness and durability without significant weight
  • Charging port and controls concealed under silicone door
Dayton Audio IO65XP 80 Watt Outdoor Installation Speaker Pair White
Price: $249.99Part # 310-041
See all items in Outdoor Speakers
Your Price: $129.95
We'll send you an email when Gemini GHRK-400-PR Outdoor Rock Speaker Pair w/ Bluetooth is back in stock or available for preorder.
Order in the next 6 hr 16 min to ship today. Details
40-Watts Peak Power
4" full-range drivers produce powerful, crystal-clear audio.
Rechargeable Battery
The GHRK-400-PR feature 2000mAh rechargeable Lithium-ion batteries. Recharge using the included micro USB cable.
Wireless Stereo Link
Easily connect both speakers using TWS (True Wireless Stereo) pairing. Enjoy your music in authentic stereo sound just as it was intended.
Withstand Any Conditions
Thanks to its weatherproof build and IPX5 rating, it's well-suited for outdoor spaces like the garden or poolside.
Unplug, Unwind, Escape
Tough construction and outdoor-ready build make it ideal for a night spent around the campfire.
Outdoor Oasis
Optimized 4" driver performance provides exceptional audio quality for outdoor environments.
1-2-3 Connect
Pair with any Bluetooth-enabled device and enjoy hassle-free playback within a 32-foot range.
Enjoy the Freedom
Forget cords and wires—simply pair the two speakers together for broader sound coverage across your yard.
Simple Setup
Step 1 - Power on Rocks
Press power button. You will hear Bluetooth Mode.
Step 2 - Automatic Linking
Speakers will attempt to pair automatically, should hear Left Speaker and Right Speaker respectively.
Step 3 - Force Linking
If auto linking doesn’t occur, Press Pair button on Master Speaker labeled A, to link. Should hear Left and Right Speaker once linked.
Step 4 - Connect Bluetooth
Find Gemini GHRK-Model in Bluetooth list & connect. LED will turn solid blue when connected.
  • Active/Passive: These rock speakers are active, meaning they have built-in amplifiers, eliminating the need for separate amplifiers or receivers. Simply connect them to a power source and enjoy your music.
  • Amplifier Class Type: The speakers feature a Class D amplifier, known for its efficiency and compact size. This amplifier technology ensures powerful sound output while minimizing energy consumption.
  • Driver Size: With 4" drivers, these rock speakers produce clear and balanced sound across a wide frequency range. Whether you're listening to soothing melodies or energetic beats, these speakers won't disappoint.
  • Total Peak Power: 20 Watts (each speaker): These rock speakers pack a punch with a total peak power of 20 Watts per speaker. Experience robust sound that fills your outdoor space with rich audio.
  • Bluetooth Version: BT5.0 – Range >32 ft. with TWS: Equipped with Bluetooth 5.0 technology, these speakers offer a stable and seamless wireless connection with your devices. Enjoy music from up to 32 feet away and pair two speakers together for true stereo sound (TWS).
  • Frequency Response: 100Hz-14kHz: The frequency response range ensures that these rock speakers reproduce a broad spectrum of sound, from deep bass notes to crisp high frequencies. Your favorite tunes will sound amazing outdoors.
  • Sensitivity and Impedance: 84dB, 4Ω: The sensitivity rating of 84dB means these speakers can produce loud and clear sound even with lower input power. The 4Ω impedance ensures efficient power transfer from the amplifier.
  • Waterproof Grade Rating: Designed to withstand outdoor conditions, these rock speakers have an IPX5 waterproof rating. They can handle splashes, rain, and even light jets of water, so you can enjoy music with ease.
  • Enclosure Material: Resonant-absorbing polymer cabinet with UV protection: The rock speaker enclosures are made of a resonant-absorbing polymer that enhances audio performance while providing durability. The UV protection ensures they won't fade or deteriorate under the sun.
  • Power Adapter: 5V micro USB cable: Conveniently power these speakers with the included 5V micro USB cable. Plug them into any USB power source, such as a wall adapter or power bank, for easy setup.
  • Battery Specs: 2000mAh Lithium-Ion Rechargeable Battery (each speaker): The built-in rechargeable batteries provide up to 10 hours of playtime at maximum volume. Enjoy wireless freedom without worrying about running out of power.
  • Play Time: UP TO 10 HOURS @ MAX VOLUME With up to 10 hours of playtime at maximum volume, these rock speakers keep the party alive. Dance to your heart's content without worrying about battery life.
  • Dimensions: (H x W x L) 9.47" in x 8.66" in x 10.63" in: These rock speakers are designed to blend into your outdoor landscape seamlessly. With their compact size and natural rock-like appearance, they won't detract from the beauty of your outdoor space.
BrandGemini
ModelGHRK-400-PR
Part Number235-101
UPC747705008381
Unit of MeasurePairs
Weight17
ColorGray
Configuration2-way
Mounting StyleLandscape
Woofer Diameter4"
Special FeaturesBluetooth Wireless-Water Resistant-Powered
