  • Gator Frameworks GFW-SPK-2000SET Standard Aluminum Speaker Stand Pair with Carry Bag
Gator CasesPart # 242-8072
Model: GFW-SPK-2000SET
The GFW-SPK-2000SET by Gator Frameworks includes two lightweight aluminum tripod speaker stands with an 81" maximum height, and a handy carrying case. Strong and secure, easy to use, and easy to afford. These are the hallmarks of Gator's Frameworks line of stands and support equipment for musicians.
  • Two durable aluminum tripod speaker stands with carrying case
  • Fits 35 mm or 38 mm cups without an adapter
  • Removable red safety rings on feet
  • 60 pound weight capacity
We'll send you an email when Gator Frameworks GFW-SPK-2000SET Standard Aluminum Speaker Stand Pair with Carry Bag is back in stock or available for preorder.
If you've been looking for a durable tripod speaker stand that won't cost you an arm and a leg, your search is over The GFW-SPK-2000SET is light in weight, but definitely not a lightweight! With an 81" maximum height and 60 pound weight capacity, each stand is up to the task. They feature a dual diameter inner tube, so they can accommodate 1-1/2" or 1-3/8" pole cups, and each has removable red safety trim on the feet, for improved visibility in dimly lit venues. With this set, you get two (2) sturdy speaker stands and a convenient carrying case.
Gator Cases is proud to introduce the Frameworks line of stands and support equipment for working musicians, students, production companies, houses of worship, and any others interested in a refreshing change in the status quo of such products. Frameworks stands are high quality gear, minus the high prices generally associated with this level of durability and user-friendliness. Try a Frameworks stand today, and we think you'll agree: there's no longer any reason to overpay for underperforming stands!
BrandGator Cases
ModelGFW-SPK-2000SET
Part Number242-8072
UPC716408533032
Unit of MeasurePairs
Weight16.9
