  • Gator Frameworks GFW-SPK-2000 Standard Aluminum Speaker Stand
Gator CasesPart # 242-8070
Model: GFW-SPK-2000
The GFW-SPK-2000 by Gator Frameworks is a lightweight aluminum tripod speaker stand with an 81" maximum height. Strong and secure, easy to use, and easy to afford. These are the hallmarks of Gator's Frameworks line of stands and support equipment for musicians.
  • Rugged aluminum tripod speaker stand
  • Fits 35 mm or 38 mm cups without an adapter
  • Removable red safety rings on feet
  • 125 pound weight capacity
Your Price: $89.99
MSRP: $143.99
Save $54.00 (38%)
We'll send you an email when Gator Frameworks GFW-SPK-2000 Standard Aluminum Speaker Stand is back in stock or available for preorder.
If you've been looking for a durable tripod speaker stand that won't cost you an arm and a leg, your search is over The GFW-SPK-2000 is light in weight, but definitely not a lightweight! With an 81" maximum height and 125 pound weight capacity, this stand is up to the task. It features a dual diameter inner tube, so it can accommodate 1-1/2" or 1-3/8" pole cups, and it has removable red safety trim on the feet, for improved visibility in dimly lit venues.
Gator Cases is proud to introduce the Frameworks line of stands and support equipment for working musicians, students, production companies, houses of worship, and any others interested in a refreshing change in the status quo of such products. Frameworks stands are high quality gear, minus the high prices generally associated with this level of durability and user-friendliness. Try a Frameworks stand today, and we think you'll agree: there's no longer any reason to overpay for underperforming stands!
BrandGator Cases
ModelGFW-SPK-2000
Part Number242-8070
UPC716408532868
Weight6.9
