  • GRS PZ1142 Piezo Bullet Horn Driver Similar to KSN1142A
GRSPart # 292-448
Model: PZ1142
Finally, an affordable drop-in replacement for those vintage KSN1142A piezos! GRS piezo tweeters are built using a 22 mm ceramic piezo element, to the original CTS specifications.
  • Perfect replacement for many classic loudspeakers
  • No crossover required - great for simple, economical designs
  • Frequency response into the ultrasonic range
  • 22 mm ceramic piezo element that follows original CTS specs
  • Equal or superior to products being sold for 8-10 times our price!
Your Price: $3.98
MSRP: $3.99
Save $0.01 (0%)
Quantity:Qty: 1-3 $3.98/ea
Quantity:Qty: 4+ $3.68/ea
Out of Stock
We'll send you an email when GRS PZ1142 Piezo Bullet Horn Driver Similar to KSN1142A is back in stock or available for preorder.
The PZ1142 is specifically designed and engineered to be a replacement for the very popular KSN1142A piezo tweeters from days gone by. Using a 22 mm ceramic piezo element, GRS piezo tweeters follow CTS' original recipe and are far superior to most look-alike piezos.
Standard 1-3/8" 18-TPI threads facilitate use with 1" horns. With a wide frequency range and ample power handling, this is also a prime candidate for new designs, especially if the crossover requirements must be kept to an absolute minimum.
Specifications: • Power handling: 60 watts RMS, 120 watts • Frequency response: 1,800-30,000 Hz • SPL: 92 dB 1W/1m • Dimensions: Diameter: 2-7/16", Depth: 1-1/2".
BrandGRS
ModelPZ1142
Part Number292-448
UPC844632005626
Weight0.15
Diaphragm MaterialPiezo Ceramic
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)60 Watts
