  • GRS DTM-8 1/2" Poly Dome Tweeter
GRSPart # 292-437
Model: DTM-8
The GRS DTM-8 is an 8ohm, 10 watt, ½” poly dome tweeter with a 2.4” (60mm) square faceplate. Great off-axis response and high sensitivity for use in 2-way and 3-way system makes this perfect as a replacement tweeter or for your next DIY project!
  • ½” poly dome tweeter provides great replacement value
  • Great off-axis response for a wide sweetspot
  • High-efficiency output for increased SPL
  • Wide bandwidth from 5kHz-20kHz
  • Low profile fits in the tightest of spaces
GRS 1TM-4 1" Mylar Tweeter 4 Ohm
Price: $4.99Part # 292-438
Goldwood GT-302 1/2" Mylar Dome Tweeter
Price: $5.98Part # 270-170
See all items in Tweeters
Your Price: $4.99
MSRP: $6.99
Save $2.00 (29%)
We'll send you an email when GRS DTM-8 1/2" Poly Dome Tweeter is back in stock or available for preorder.
Ships in 90-120 days, minimum order quantity 1,000 pcs.
High-Frequency At A Low Cost
The GRS DTM-8 is a poly dome tweeter with low distortion characteristics and predictable performance, making this a great component for speaker designers. The direct drive design and built-in phase plug enhance off-axis performance, giving you better sound all around!
Key Specs:
  • Power Handling (RMS): 5W
  • Power Handling (MAX): 10W
  • Impedance: 8ohm
  • Frequency Response: 5kHz-20kHz
  • Sensitivity: 96dB @ 2.83v/1m
  • Voice Coil Diameter: 1"
Frequency Response & Impedance Curve
the GRS DTM-8 has a wide frequency response from 5kHz to 20kHz and has a highly uniform off-axis response. This uniformity lends itself well to high-frequency applications in full range cabinets.
High Value
The GRS DTM-8 has a lightweight poly dome that minimizes resonance at higher frequencies and allows uniform off-axis dispersion which is enhanced by the built-in phase plug. The low profile of the DTM-8 allows this to fit in the tightest of spaces, making the DTM-8 a great choice as a replacement driver or for your next project!
Incredibly Versatile
The GRS DTM-8 poly dome tweeter is a great choice to add detail to any full-range speaker! Thanks to the built-in phase plug and the direct drive design, the DTM-8 performs with minimal changes to the output response when listening off-axis.
We've Got Your Back
Learn More
BrandGRS
ModelDTM-8
Part Number292-437
UPC848864069562
Weight0.2
