  • Furman VT-EXT Equipment Rack Power Distribution
CLEARANCE Furman VT-EXT Equipment Rack Power Distribution
Furman SoundPart # 248-7850
Model: VT-EXT
If you need more outlets in your rack, but you already have a conditioner or surge protection installed, the VT-EXT is for you. Eight outlets, three with transformer spacing, can be added to your rack quick and easy.
  • Eight AC outlets on a handy power strip
  • Mounts to your rack quick, easy, and secure
  • 12A resettable circuit breaker
  • Detachable 10 ft. 14AWG power cord
We'll send you an email when Furman VT-EXT Equipment Rack Power Distribution is back in stock or available for preorder.
Furman's VT-EXT gives you 8 extra outlets on a sturdy power strip designed specifically to be mounted to the vertical leg section of an equipment rack. The VT-EXT is the perfect extension of protection and filtration from an existing Panamax or Furman power conditioner.
Simply attach the included mounting clips in the desired location for an easy installation. Snap the VT-EXT into the clips for a sturdy and secure fit, then plug into a Panamax/Furman power conditioner. The plastic spacers in clips provide ground isolation from the rack.
Note: the VT-EXT is a power distributor only, and offers no surge protection or conditioning functions, making it an ideal extension to an existing branch circuit.
BrandFurman Sound
ModelVT-EXT
Part Number248-7850
UPC050616008969
Weight2.4
