  • Furman RS-2 System Control Panel with Momentary Key Switch
CLEARANCE Furman RS-2 System Control Panel with Momentary Key Switch
Furman SoundPart # 248-7868
Model: RS-2
The RS-2 Remote System Control Panels provide a simple way to control AC equipment from one or more locations, using only inexpensive, low-voltage wiring.
  • Fits a standard single gang wall box
  • Powder-coated metal construction
CLEARANCE $37.95
MSRP: $83.95
Save $46.00 (55%)
2 In Stock
We'll send you an email when Furman RS-2 System Control Panel with Momentary Key Switch is back in stock or available for preorder.
The panel can be easily installed in a single gang switchbox with a minimum depth of 1.5”. Features include a locking key switch and a ”System On” indicator LED. The RS-2 has a maintained contact ”Start ON/OFF Sequence” push-button. The rear of the panel has a circuit board with a full size barrier strip for field wiring connections.
The RS-2 can be used to control the Furman ASD-120 Sequenced Power Distributor, the Power Link, Power Port, Remote AC Controller, the MiniPort Power Relay series, or the PS-8R, PS-8R II or PS-PRO II Power Sequencers, as well as other equipment that needs a switch contact at a remote location. Limit one per system.
BrandFurman Sound
ModelRS-2
Part Number248-7868
UPC654061003045
Weight0.35
