  • Furman PL-PLUS DMC Rack Mount 9 Outlet Power Conditioner 15A
CLEARANCE Furman PL-PLUS DMC Rack Mount 9 Outlet Power Conditioner 15A
Furman SoundPart # 248-781
Model: PL-PLUS DMC
The Classic Series from Furman brings together superior protection and outstanding performance. The PL-PLUS DMC has all the great features of the PL-8 C, but adds a large digital voltmeter / ammeter, with discrete dimmer button, to display line voltage and true RMS current draw.
  • Furman's exclusive SMP technology provides the highest level of surge & spike protection available
  • LiFT offers AC power filtering to ensure clean power for unequaled audio & video clarity
  • Advanced EVS circuitry detects dangerous voltage irregularities and safely powers down
  • Large digital voltmeter / ammeter displays line voltage and true RMS current draw
  • Dual smooth-track retractable LED lights illuminate equipment in your rack
  • LED indicators warn you when voltage is outside of nominal range or protection has been compromised
  • Isolated outlet banks minimize inter-component interference and noise contamination
CLEARANCE $524.95
MSRP: $608.95
Save $84.00 (14%)
2 In Stock
We'll send you an email when Furman PL-PLUS DMC Rack Mount 9 Outlet Power Conditioner 15A is back in stock or available for preorder.
The Classic Series from Furman brings together superior protection and outstanding performance in a sturdy, rack-mountable design. The Classic Series features Furman's revolutionary Series Multi-Stage Protection (SMP), Linear Filtering Technology (LiFT), and Extreme Voltage Shutdown (EVS). Together, these technologies comprise what is, without question, one of the world's most advanced and comprehensive transient voltage surge suppressors.
Specifications: • 9 Outlet (8 on rear and 1 on front)put current: 15 amps • Line cord: Captive 3/14 AWG, 10 ft. black cord with NEMA 15 plug • Pull-out lights: Two multi-LED, dimmable lamps • BNC socket with switch: Rear rack lamp, 12 VAC 500mA max (lamp not included) • Operating voltage: 90 to 139 VAC • Spike protection mode: Line to neutral, zero ground leakage • Spike clamping voltage: 188 VAC peak @ 3,000 Amps • Response time: 1 nanosecond • Maximum surge current: 6,500 Amps • Noise attenuation: 10 dB @ 10 kHz, 40 dB @ 100 kHz, 50 dB @ 500 kHz • Power consumption: 12 watts • Dimensions: 19" W x 1.75" H (1RU) x 10.5" D.
Applications
Instrument Rigs
You've got a rack for your effects, preamps, tuner...You're going to plug that into the wall? One big spike and your rig is up in smoke. Furman's advanced Series Multi-Stage Protection defends your gear from the spikes and surges that are so common at gigs and practice spots. With Furman's advanced Linear Filtering Technology, you'll get a quieter tone without pops, crackles, and the local radio station coming out of your amp.
Recording
Can't track down where that noise is coming from? Your mix sounding flat? With Furman's advanced Linear Filtering Technology you'll lower the noise floor caused by the dirty AC power coming into your console or DAW. Furman's advanced Series Multi-Stage Protection keeps your sensitive digital equipment from acting funny or burning up due to everyday spikes and surges. With a 15A capacity and 9 total outlets, it's enough to power your whole home studio.
DJ Equipment
Bars, clubs, and other event venues have some of the worst power out there - from air compressors turning on and off to light shows pulling current loads up and down, the AC power can be a strain on the circuits in your rig. Furman's advanced Series Multi-Stage Protection and LiFT keeps the bad stuff out and the dual pull-out front panel lights let you discreetly see your board and gear without distracting from the show on the dance floor.
Pro Audio
When you're out there gigging, you never know what kind of power you're going to get. The wear and tear on mobile rigs eventually takes it toll - that's why it's smart to plug into Furman's advanced Linear Filtering Technology. It keeps your equipment safe and sounding clean. Whether you're setting up a show at the local club or powering up the church band for their next service, make sure you give them power they can trust.
BrandFurman Sound
ModelPL-PLUS DMC
Part Number248-781
UPC654061027980
Weight12.55
ColorBlack
Cord Length10'
Number of Outlets9
Special FeaturesRack Mountable
