  • Furman M-8S Power Sequencer
Furman SoundPart # 248-7854
Model: M-8S
A Merit Series power conditioner and sequencer from Furman is the perfect low-cost AC power solution for any rack mount system. Install an M-8S in the top slot of your rack, and six outlets in the rear panel will power up in sequence, and protect all your equipment up to a 15-amp load.
  • AC noise filtering to reduce radio frequency and electromagnetic interference (RFI/EMI)
  • Spike & surge protection ensures equipment stays safe and your power stays clean
  • 9 total outlets - 8 rear panel outlets (6 sequenced) and 1 front panel outlet
  • 15 amp rating, with circuit breaker
  • Rear outlets have been spaced to accommodate even the bulkiest of wall warts and adapters
Your Price: $415.95
MSRP: $469.95
Save $54.00 (11%)
We'll send you an email when Furman M-8S Power Sequencer is back in stock or available for preorder.
A Merit Series power conditioner and sequencer from Furman is the perfect low-cost AC power solution for any rack mount system. Install an M-8S in the top slot of your rack, and six outlets in the rear panel will power up in sequence (two outlets at a time) and protect all your equipment up to a 15-amp load. There are an additional two outlets on the rear panel, and a front panel convenience outlet, all of which are unswitched.
Specifications: • Maximum output current: 15 amps • Line cord: 10 ft., captive, 14 AWG, with 3-conductor Edison plug • Operating voltage: 120 VAC, 60 Hz • Spike protection mode: Line to neutral • Energy rating: 225 joules • Max clamp voltage: 500V • Peak impulse current: 12,000 amps • Maximum continuous operating voltage: 130 VAC RMS • Noise attenuation: Standard level Pi LCR filter, >26 dB, 100 kHz to 10 MHz • Dimensions: 1.75" H x 19" W x 8.75" D • Weight: 7 lbs. • Safety agency listing: C/CSA/US • Three-year limited manufacturer's warranty.
BrandFurman Sound
ModelM-8S
Part Number248-7854
UPC654061041078
Weight7.6
ColorBlack
Cord Length10'
Number of Outlets9
Special FeaturesRack Mountable
