  • Fourjay ST4P-CR8 8" Ceiling Speaker Assembly w/Vol Control
CLEARANCE Fourjay ST4P-CR8 8" Ceiling Speaker Assembly w/Vol Control
Fourjay IndustriesPart # 300-348
Model: ST4P-CR8
Factory assembled and pre-tested to pass the highest quality standards. Compact 11" diameter is less conspicuous than comparable models.
We'll send you an email when Fourjay ST4P-CR8 8" Ceiling Speaker Assembly w/Vol Control is back in stock or available for preorder.
Factory assembled and pre-tested to pass the highest quality standards. Compact 11" diameter is less conspicuous than comparable models. The ST4P-CR8 utilizes a molded polystyrene grill with a non-glare ceiling white texture. It has an impedance of 8 ohms and is rated at 10 watts. The ST4P-CR8 is fitted with a 25/70 volt transformer and a recessed 50 ohm volume control.
Speaker Model #Q88D5
Transformer Model T427
Size & Style8" RoundPower Rating4 Watts
Magnet Weight & Type5 oz. CeramicPrimary Voltage25 & 70
Speaker TypeDual ConeInsertion Loss @ 1 KHz0.9 dB
Power Rating15 WattsFrequency Response80-20,000 Hz
Sensitivity96 dBPrimary Taps4, 2, 1, 1/2 Watts
Response40-18,000 HzPrimary Leads6" Color Coded
Impedance8 OhmsSecondary Impedance8 Ohms
Coil Diameter3/4"Secondary Leads6" Color Coded
Depth2-3/4"Mounting Centers2"
Weight1.4 Lbs.Weight0.42 Lbs.
2001 Parts Express. All Rights Reserved
BrandFourjay Industries
ModelST4P-CR8
Part Number300-348
UPC844632007514
Weight3.1152
Input Rating8 ohm|70V|25V
Mounting StyleIn-ceiling
Woofer Diameter8"
Special FeaturesVolume Control
