Fourjay PB8 Metal Drop Ceiling Tile Bridge UL Listed
We'll send you an email when Fourjay PB8 Metal Drop Ceiling Tile Bridge UL Listed is back in stock or available for preorder.
Extra 15% off Outlet Center items with code STOCK15. SHOP NOW
Ends 10/26 at 11:59pm ET.
The Fourjay PB8 is a UL listed tile bridge for drop ceiling speaker installation. It distributes the weight of your speaker assembly across the tee-bars of your suspension grid rather than the tile itself, and is compatible with Fourjay 8" speaker assemblies with a 9-1/4" mounting pattern, as well as larger baffles with a 11-1/4" screw pattern. The PB8 is also compatible with the PE8 backbox enclosure, which can be quickly and easily snapped into place with no mounting hardware required.
Specifications: • Inside cutout diameter: 7-5/8" • 14" W x 23-3/4" L • Screw holes: 9-1/8" and 11-1/4" diameter circles.
Product Details | |
| Brand | Fourjay Industries |
| Model | PB8 |
| Part Number | 300-311 |
| UPC | 844632007453 |
| Unit of Measure | Each |
| Weight | 1.7226 |
