  • Fosi Audio ZP3 Preamplifier
NEW Fosi Audio ZP3 Preamplifier
Fosi AudioPart # 235-261
Model: ZP3
The Fosi Audio ZP3 is a balanced 2.0 preamplifier built to serve as a home audio control hub, giving you three source inputs, three outputs, remote operation, and user-adjustable sound controls in one component. It is positioned for systems that need flexible source switching, subwoofer integration, and cleaner system matching across RCA and XLR connections.
  • 3-in-3-out design for connecting up to three audio sources with easier system control
  • RCA1 RCA2 and XLR inputs with RCA XLR and sub outputs for broad system compatibility
  • Three-level high-pass filter to direct lows to the sub output and keep mids and highs going to the main speakers
  • Bass treble bypass and L/R balance controls for more personalized sound adjustment
  • Per-input volume memory for quicker return to your preferred settings on each source
  • 12V trigger in/out and included remote for more convenient daily operation
Fosi Audio P4 Mini Preamp w/ Remote Control
Price: $99.99Part # 235-282
See all items in Home Audio Amplifiers
NEW $199.99
We'll send you an email when Fosi Audio ZP3 Preamplifier is back in stock or available for preorder.
Order in the next 0 hr 24 min to ship today. Details
A Versatile Control Hub for Home Audio
Tailor your audio system with 3 inputs/outputs, a high-pass filter (HPF), and tone controls. The included remote allows one-touch input switching and volume adjustment, while volume memory saves your preferred audio settings.
Built on User Voices
The ZP3 Balanced Preamp was created in response to customer demand for a preamplifier with multiple audio inputs.
  • Input: RCA x2 and XLR
  • Output: RCA, XLR, SUB
  • SNR≥ 115dB; SINAD≥113dB; Crosstalk≤ -130dB
  • Input Voltage Range: AC 110-240V
Flexible Sound Customization
Bass and treble bypass, plus left/right balance adjustment. Per-input volume memory adds more personalized and intuitive audio control.
Audiophile-Grade Components Integrated
Built without compromise in material quality, delivering low noise and accurate sound for a premium audio experience.
Visible Exceptional Performance
Sound quality is no longer just something you hear, its excellence can now be seen.
Multi-Function IR Control
Easily adjust the volume, switch sources, and control the power on/off without leaving your seat.
Aluminum-Alloy
Metallic finish with improved resistance to electromagnetic interference.
ZP3 & P4 Comparison
Thinking about a new preamp? Let’s line up P4 and ZP3, and see what makes each one special.
Home Audio Control Center
Offers 3-in-3-out connectivity for linking up to three audio sources. An included remote provides one-touch input switching and volume control, making everyday operation of your home audio system simple and convenient
Wide-Ranging Connectivity
With RCA1/RCA2/XLR inputs and RCA/XLR/Sub-Out outputs, the ZP3 connects easily with a variety of devices. Balanced XLR input and output support cleaner signal transfer, while RCA/XLR conversion adds broader system compatibility
High-Quality Internal Components
Uses premium parts such as ELNA capacitors, the NJR NJU72315 volume IC, and gold-plated RCA jacks. Together, these components help lower noise and distortion for clear, high-fidelity sound
Selectable High-Pass Filter
A three-level HPF lets you filter low-frequency content from the RCA/XLR outputs, sending mids and highs to your main speakers while directing bass to the SUB-OUT. This improves clarity, detail, and overall system balance
Personalized Sound Control
Includes bass and treble adjustment with a bypass option, along with left/right balance control for more tailored tuning. Volume memory stores settings for each input source, creating a more convenient and customized listening experience
  • Channel: 2.0
  • Input: RCA x2, XLR
  • Bass and Treble Control Range: Treble: ±6dB,Bass: ±12dB
  • Frequency Response
    XLR/RCA
    -20Hz-20kHz (±0.2dB)
    -80Hz-20kHz (±0.2dB)
    -120Hz-20kHz (±0.2dB)
    SUB: 20Hz-200Hz (±0.2dB)
  • Balanced Output (XLR):
    -SNR: ≥ 112 dB
    -Dynamic Range: ≥ 112 dB
    -THD+N: ≤ 0.0007%
    -Noise Floor: ≤ 6μV
  • Single-Ended Output (RCA):
    -SNR: ≥ 115 dB
    -Dynamic Range: ≥ 115 dB
    -THD+N: ≤ 0.0008%
    -Noise Floor: ≤ 4μV
  • Gain for RCA Output: 8.8 dB
  • Gain for XLR Output: 14 dB
What‘s in the box?
  • Fosi Audio ZP3 x 1
  • IR Remote Control x 1
  • AC 110-240V Power Cord x 1
  • 12V Trigger Cable x 1
  • User Manual x 1
BrandFosi Audio
ModelZP3
Part Number235-261
Weight3.45
Weight Range< 10 lbs.
