  • Fosi Audio V3 Stereo Amplifier and Q4 Mini DAC/Headphone Amplifier Bundle
Fosi AudioPart # 235-294
The Fosi Audio V3 and Q4 bundle pairs a compact 2-channel power amplifier with a desktop DAC/headphone amp for a simple wired home audio system. Together, they combine the V3’s TPA3255-based speaker amplification with the Q4’s USB, optical, and coaxial digital inputs, headphone output, RCA output, and tone controls for more flexible desktop or stereo use.
  • USB, optical, and coaxial digital inputs make it easier to connect a range of digital sources to the Q4
  • 3.5mm headphone jack and RCA outputs let the Q4 serve both headphone and speaker-based systems
  • Bass and treble controls provide more direct tonal adjustment from the DAC/headphone amp
  • The Q4 can be used as a preamp or volume controller for a more flexible desktop audio chain
  • Built-in TI TPA3255 amplification gives the V3 compact Class D speaker power with low distortion
  • 300W x 2 maximum output gives the V3 strong 2-channel power in a compact format
  • Swappable op-amps let the V3 support sound-signature customization
Your Price: $162.99
Save $36.99 (18%)
Designed with Audiophiles in Mind
Integrated high-quality components and an innovative heat dissipation design ensure stable, high-performance output that meets the expectations of discerning audiophiles.
TI TPA3255 Integrated
Delivers superior audio quality and ultra-low distortion across the full frequency range while maintaining the high efficiency of Class-D amplification.
    Q4 Mini Stereo Gaming DAC and Headphone Amplifier
  • PC-USB supports input sampling rate: 24Bit/96kHz
  • High and low sound adjustment range: ±6dB
  • Fiber/coaxial support input sampling rate: 24Bit/192kHz
  • Frequency response: 20Hz-20kHz (±3dB)
  • PC-USB support operating system: XP/W7/W8/W10/MAC/Linux
  • Distortion: 0.01%
  • Signal-to-Noise Ratio (SNR): ≥105dB
  • Amp output maximum power: 100mW 32 Ohm load
  • Headphone matching impedance: 16-200 Ohms
  • Working voltage:  DC 5V
  • RCA output level: 2.3V
  • Size: 2.89" L x 3.86" W x 1.3" H (without knobs and terminals)
V3 Stereo Amplifier
  • Chip Set: TI TPA3255
  • Output Power: 300Wx2 @4Ω
  • Terminating Impedance: 2-8Ω
  • Input Mode: RCA
  • Output Mode: Speaker Output + Pre-out
  • Frequency Range: 20Hz-20kHz(±0.1dB)
  • SINAD: 88dB
  • THD: 0.003%
  • SNR: ≥110dB
  • Control Knob: Built-in Logarithmic Taper A pot
  • Device Dimension: 6.5x4.1x1.4 inches
  • DC Input Range: 24-48V
  • Power Supply: 32V/5A, 48V/5A
BrandFosi Audio
Part Number235-294
UPC848864082462
Weight3.53
Power (RMS/Channel 8 ohms)101 - 250 Watts
Weight Range< 10 lbs.
