  • Flip Up Stage Box with Pre-Punched Panel for Four D-Style Connectors
Parts ExpressPart # 240-304
Our rugged flip-up pocket boxes clean up the cable clutter found on typical stages, studios, houses of worship, classrooms, or boardrooms. This floor box features a pre-punched panel that will accommodate four D-style connectors of your choice..
  • 12 gauge steel construction stands up to hard use
  • Tapered carpet trim ring reduces snags and trip hazards
  • Interchangeable side panels for maximum flexibility
  • Removable bottom panel facilitates installation
  • Cable slots in door help cables lay flat
Your Price: $72.98
MSRP: $141.99
Save $69.01 (49%)
We'll send you an email when Flip Up Stage Box with Pre-Punched Panel for Four D-Style Connectors is back in stock or available for preorder.
Order in the next 3 hr 13 min to ship today. Details
Pocket boxes offer a convenient point of access for cables while protecting the connectors from unintentional damage. Our flip-up boxes are made from 12 gauge steel to stand up to the rigors of life on the big stage. Durable construction and built-in adaptability make these boxes suited perfectly for use in-wall, in a desk or lectern, or just about anywhere convenient cable access is desired. Slanted connector panels provide easier connector access, while 1-1/4" long cable slots in the cover allow it to remain closed while in use. The box's tapered carpet ring provides a finished appearance for any installation.
Each box features removable and interchangeable side panels, pre-loaded with connectors or pre-punched to accommodate standard type "D" connectors. Removable bottom panels can be drilled or punched to meet your installation's unique needs. Two box styles are available.
Dimensions: • Internal pocket size: 3-3/4" L x 4-3/4" W x 2-3/8" D • Overall external dimensions: 8" L x 8" W x 3" D.
Part Number240-304
UPC848864017877
Weight3.8
