Enjoy a superior listening experience with the FiiO E10K desktop USB DAC with built in headphone amplifier. Top of the line electronics and hardware are matched well to its handsome design. Stream files at a sample rate up to 96 kHz/24-bit and hear all the difference through the E10Ks powerful built-in headphone amplifier. The LMH6643 op-amp creates superior transient response and driving power. Connection is made via the micro USB input on the rear of the chassis. Outputs include coaxial, 3.5 mm, and 3.5 mm headphone outputs. A USB micro cable is included with the E10K.
Specifications: • Power output: 200 mW @ 32 ohms • Sample rate: 96 kHz/24-bit • Frequency response: 20-20,000 Hz • Signal to noise ratio: ?105 dB • THD: <0.006% • Impedance: 16-150 ohms • Power supply: Micro USB port • Dimensions: 1.93" W x 3.11" D x 0.83" H.
