  • Muffin Cooling Fan 100-125 VAC 77/86 CFM 4-5/8" x 1-1/2" RAM1238S2
CLEARANCE Muffin Cooling Fan 100-125 VAC 77/86 CFM 4-5/8" x 1-1/2" RAM1238S2
Parts ExpressPart # 259-150
Popular, high output 85 CFM 120 mm AC fan used in larger electronic equipment and rack cooling features a 7-blade plastic impeller and aluminum alloy frame. Power cord not included. Made in Taiwan.
  • Standard 120 mm x 120 mm x 38 mm frame size
  • 7-blade plastic impeller
  • Rugged aluminum alloy frame
  • Sleeve bearing
We'll send you an email when Muffin Cooling Fan 100-125 VAC 77/86 CFM 4-5/8" x 1-1/2" RAM1238S2 is back in stock or available for preorder.
Popular-sized, high output 85 CFM AC fan that's used in larger electronic equipment and rack cooling features a 7-blade plastic impeller and aluminum alloy frame. Power cord not included. Made in Taiwan.
Specifications: • Input voltage: 100-125 VAC • Frequency.: 50/60 Hz • Current: 0.25 A • Power: 15/14 W • Maximum air flow: 85 CFM • Noise: 40/42 dBA • Static pressure: 5.3/7.2 • Bearing system: Sleeve • Dimensions: 4-5/8" H x 4-5/8" W x 1-1/2" D (120 x 120 x 38 mm) • Mounting holes: 4-1/8" (105 mm) O.C. • Safety approvals: CE, UL recognized • Model: RAM1238S2.
Part Number259-150
UPC844632039515
Weight1.25
Bearing TypeSleeve Bearing
Operating Voltage110~120 VACV
Size120
