  • FaitalPRO HMF200 Neodymium Compression Horn Driver 8 Ohm 4-Bolt
NEW FaitalPRO HMF200 Neodymium Compression Horn Driver 8 Ohm 4-Bolt
FaitalPROPart # 294-1081
Model: HMF200
The HMF200 is a 2" (50.8 mm) throat compression driver crafted for professional audio systems that require high-efficiency high-frequency reproduction with minimal input power. Built to perform in compact horn-loaded installations, it provides clarity and strong output in the critical high band.
  • 1.46" (37 mm) aluminum voice coil on Kapton former supports thermal stability
  • Frequency range from 450 Hz to 9 kHz for broad high-end coverage
  • Flux density of 2.1 T drives strong motor force
  • 2" (50.8 mm) throat diameter with combined exit plate design
  • Made in Italy
NEW $442.00
We'll send you an email when FaitalPRO HMF200 Neodymium Compression Horn Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 15 hr 24 min to ship today. Details
The HMF200 offers high-sensitivity 108 dB output and a 40 W AES rating, allowing it to deliver clear and powerful high frequencies without the need for oversized amplification. A 1.46" (37 mm) aluminum voice coil on a Kapton former enhances durability under thermal stress. The wide 450 Hz to 9 kHz frequency band allows flexible integration in professional sound systems where clarity in the upper mid and high frequencies is crucial. With a strong neodymium ring magnet delivering 2.1 T flux, the driver maintains clean motion and reliability even under heavy use. Compact mechanical dimensions ensure easy fit in tight horn or compression driver modules, making the HMF200 a dependable solution for professional horn-loaded systems.
BrandFaitalPRO
ModelHMF200
Part Number294-1081
UPC848864081861
Weight4.2
Diaphragm MaterialPaper / Composite
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)40 Watts
Impedance8Ω
