  • FaitalPRO HF1440 Neodymium Compression Horn Driver 8 Ohm 4-Bolt
FaitalPROPart # 294-1077
Model: HF1440
The HF1440 is a 1.4" (35.8 mm) exit compression driver designed for professional audio systems that demand high-efficiency output and extended bandwidth. With 120 W AES power handling and 109 dB sensitivity, it offers crisp, articulate high-frequency performance and robust durability.
  • 3.4" (86 mm) aluminum voice coil on Kapton former for thermal stability
  • Neodymium ring magnet with 2.2 T flux density ensures strong motor force
  • Frequency range from 0.5–20 kHz for wide high-end coverage
  • Made in Italy
FaitalPRO HF206 Neodymium Compression Horn Driver 8 Ohm 4-Bolt
Price: $394.00Part # 294-1079
See all items in Horn Drivers
Your Price: $617.00
We'll send you an email when FaitalPRO HF1440 Neodymium Compression Horn Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Order in the next 2 hr 10 min to ship today. Details
The HF1440 combines a 120 W AES power rating with a high 109 dB sensitivity to deliver clear and powerful high-frequency response in demanding sound systems. Its 3.4" (86 mm) aluminum voice coil mounted on a Kapton former offers excellent heat resistance during extended use. The neodymium ring magnet, rated at 2.2 T flux density, provides strong magnetic drive for clean, controlled output. With a wide frequency range beginning at 0.5 kHz and extending to 20 kHz, the driver covers full high-frequency performance, making it suitable for horn-loaded applications. The compact throat diameter of 1.4" (35.8 mm), overall diameter of 4.9" (124 mm), and mounting depth of 3" (75 mm) allow for flexible installation across professional systems.
BrandFaitalPRO
ModelHF1440
Part Number294-1077
UPC848864081823
Weight4.9
Diaphragm MaterialPoly / Mylar
Exit Diameter1.4"
Mounting Type4-Bolt
Power Handling (RMS)120 Watts
