CLEARANCE FaitalPRO HF1440 1.4" Neodymium Compression Horn Driver 8 Ohm
- Produces 500 to 20,000 Hz with low distortion and high output
- Under 5" diameter and still delivers better performance than much larger drivers
- Powerful neodymium motor provides optimum control for the voice coil and diaphragm
- Keytone polymer diaphragm has excellent damping properties for remarkable flat response
- 1.4" throat with standard 4-bolt mount for use with many popular horns
We'll send you an email when FaitalPRO HF1440 1.4" Neodymium Compression Horn Driver 8 Ohm is back in stock or available for preorder.
