  • FaitalPRO HF108 1" Neodymium Compression Horn Driver 8 Ohm 2/3-Bolt
FaitalPROPart # 294-1055
Model: HF108
Designed to produce for use in high output sound systems, Faital Pro's HF108 1" Ketone polymer compression driver produces remarkably flat response up to 20,000 Hz with incredible detail and accuracy. The is the perfect high frequency driver for use in high efficiency home speakers, live sound systems, and high output mobile sound systems.
  • Optimized diaphragm and motor system to produce extremely flat and accurate response
  • Ketone polymer diaphragm and optimized phase plug for natural and smooth response
  • Powerful neodymium motor for minimal size and weight without sacrificing efficiency
  • Can handle crossovers as low as 1,300 Hz for easy transition to midrange drivers
Your Price: $247.00
We'll send you an email when FaitalPRO HF108 1" Neodymium Compression Horn Driver 8 Ohm 2/3-Bolt is back in stock or available for preorder.
Faital Pro's powerful HF108 1" exit Ketone polymer compression driver is a great choice for use in high output live sound and automotive SPL systems. The HF108R's naturally damped diaphragm and optimized annular phase plug ensure extremely flat and detailed response all the way up to 20,000 Hz. Thanks to the powerful neodymium motor, size and weight has been kept to a minimum while still producing the extreme efficiency and low distortion that Faital Pro's compression drivers are known for. The characteristics of the HF108 1" compression driver makes it ideal for use in any design where you need extreme output capability and incredible accuracy.
Specifications: • Power handling: 60 watts RMS with minimum crossover of 1,300 Hz at 12 dB per octave • VCdia: 1.73" • Impedance: 8 ohms • Frequency response: 1,000-20,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 3.43" diameter x 1.61" depth • Net weight: 1.8 lbs.
BrandFaitalPRO
ModelHF108
Part Number294-1055
UPC848864063010
Weight2.1
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type2-Bolt/3-Bolt
Power Handling (RMS)60 Watts
