  • FaitalPRO 8PR320 8" Neodymium Professional Midbass 8 Ohm
FaitalPROPart # 294-1166
Model: 8PR320
Ideal for lightweight portable speaker systems, the Faital Pro 8PR320 8” professional woofer weighs only 5.4 pounds, but will deliver surprisingly powerful bass response with smooth output all the way up to 4,000 Hz. With a 2.65” voice coil, compact neodymium motor, and weatherproof cone this driver will deliver the performance and reliability that Faital Pro is known for. The 8PR320 is an ideal driver for 2-way DJ systems, segmented line arrays, high output home theaters, and even motorcycle sound systems.
  • 95 dB sensitivity to provide incredible output even when driven with modest power
  • Powerful low frequencies and smooth response to 4,000 Hz is perfect for 2-way designs
  • Weatherproof treated paper cone allows reliable use in harsh environments
  • Large 2.65” voice coil to handle up to 300 watts RMS to produce extreme SPL
  • Lightweight neodymium motor lowers weight without sacrificing performance
Your Price: $293.00
Only 2 In Stock
We'll send you an email when FaitalPRO 8PR320 8" Neodymium Professional Midbass 8 Ohm is back in stock or available for preorder.
Faital Pro’s 8PR320 8” professional neodymium woofer is built to deliver high output with smooth response. Weighing in at only 5.5 pounds thanks to the FEM-optimized magnet assembly, this is an excellent choice for use in portable 2-way sound systems. The weatherproof treated paper cone has outstanding damping properties allowing the 8PR320 to provide natural response up to 4,000 Hz with low distortion and minimal breakup. A 2.65” high temperature voice coil with effective venting handles up to 300 watts RMS without issue, even during extended high output listening sessions. Low Fs and 7.33 mm Xmax allow significant bass response with impressive impact and control. Thanks to incredible performance, dynamics, and reliability, the 8PR320 is a great choice for everything from portable professional sound systems to high SPL car audio designs.
BrandFaitalPRO
Model8PR320
Part Number294-1166
UPC848864068534
Weight5.6
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Frequency Response60 to 4,000Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter2.56"
Resonant Frequency (Fs)65Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)0.52mH
Mechanical Q (Qms)8.2
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)0.46ft³
Mechanical Compliance of Suspension (Cms)0.19mm/N
BL Product (BL)12.9T·m
Diaphragm Mass Inc. Airload (Mms)31.7g
Maximum Linear Excursion (Xmax)7.33mm
Surface Area of Cone (Sd)223cm²
Cone MaterialTreated Paper
Surround MaterialTreated Paper
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter8.81"
Baffle Cutout Diameter7.2"
Depth3.92"
Sealed Volume0.3ft³
Sealed F3127.1Hz
Vented Volume0.63ft³
Vented F359Hz
