  • FaitalPRO 8HX210 8" Coaxial Speaker 8 Ohm
FaitalPROPart # 294-1088
Model: 8HX210
The FaitalPRO 8HX210 is an 8″ two-way coaxial loudspeaker driver that combines a mid/bass driver and a high-frequency tweeter in a single axis design for coherent source imaging. It’s engineered for professional applications where compact size and broad frequency coverage matter.
  • 8″ coaxial design with integrated mid/bass and neodymium tweeter
  • 200 W AES power handling (mid/bass) and 35 W AES (tweeter)
  • Sensitivity of 94 dB (mid/bass) and 104 dB (tweeter)
  • Frequency range from 75 Hz to 20 kHz for wide-band coverage
  • 52 mm mid/bass voice coil and 37 mm dome tweeter for balanced driver integration
  • 90° dispersion angle for controlled coverage in two-way systems
  • Durable materials including aluminum basket and treated polycotton surrounds
Your Price: $393.00
We'll send you an email when FaitalPRO 8HX210 8" Coaxial Speaker 8 Ohm is back in stock or available for preorder.
FaitalPRO 15HX500 15" Neodymium Professional Coaxial Driver 8 Ohm
BrandFaitalPRO
Model8HX210
Part Number294-1088
UPC848864082240
Weight8.9
Nominal Diameter18"
Bolt Circle Diameter17.32
Impedance8Ω
Frequency Response30 to 1600Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter3.54"
Resonant Frequency (Fs)34Hz
DC Resistance (Re)6.2Ω
Voice Coil Inductance (Le)1.5mH
Mechanical Q (Qms)6.8
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.4
Compliance Equivalent Volume (Vas)8.72ft³
Mechanical Compliance of Suspension (Cms)8.72mm/N
BL Product (BL)24T·m
Diaphragm Mass Inc. Airload (Mms)182.3g
Maximum Linear Excursion (Xmax)13.8mm
Surface Area of Cone (Sd)1213cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter18.11"
Baffle Cutout Diameter16.61"
Depth8.46"
