  • FaitalPRO 6PR160 6" Professional Neodymium Midbass 8 Ohm
FaitalPROPart # 294-1320
Model: 6PR160
Built to produce accurate and realistic vocal reproduction, even at extreme levels, the FaitalPRO 6PR160 6" midbass driver is ideally suited for high output hi-fi systems and sound reinforcement designs. Equipped with a powerful neodymium motor, aluminum shorting ring, damped paper cone this driver delivers extremely low distortion even when driven to its limit.
  • Incredibly flat response even at 45° off axis, perfect for high output line arrays
  • Neodymium motor and cast aluminum frame keeps weight to a minimum
  • Waterproof treated paper cone allows use in damp locations and outdoor installations
  • Fiberglass voice coil former and extensive venting to handle high power for extended periods
Your Price: $202.00
We'll send you an email when FaitalPRO 6PR160 6" Professional Neodymium Midbass 8 Ohm is back in stock or available for preorder.
Estimated back in stock 10/23/2026
The 6PR160 6" midbass from FaitalPRO delivers accurate and detailed midrange response making it an excellent driver for use in high efficiency 3-way designs and medium sized line array systems. This compact but powerful driver uses a strong neodymium motor and rigid cast aluminum frame to cut weight without sacrificing efficiency. The motor system includes extensive venting and an inductance reducing shorting ring for low distortion with minimal power compression. Treated with a waterproof coating, the naturally damped paper cone allows the 6PR160 to produce natural and accurate response and extremely wide dispersion. This is a versatile 6" driver that is capable of covering the entire vocal range even when driven to extreme output levels
BrandFaitalPRO
Model6PR160
Part Number294-1320
UPC848864063102
Weight2.6
Nominal Diameter6"
Bolt Circle Diameter6.77
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Impedance8Ω
Frequency Response80 to 80,000Hz
Sensitivity95dB 2.83V/1m
Voice Coil Diameter1.46"
Resonant Frequency (Fs)90Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.28mH
Mechanical Q (Qms)6.6
Electromagnetic Q (Qes)0.35
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)0.17ft³
Mechanical Compliance of Suspension (Cms)0.25mm/N
BL Product (BL)11T·m
Diaphragm Mass Inc. Airload (Mms)12.5g
Surface Area of Cone (Sd)117cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter6.37"
Baffle Cutout Diameter5.79"
Depth2.87"
Vented Volume0.3ft³
Vented F381.5Hz
