  • FaitalPRO 21XL3000 21" Neodymium Subwoofer 8 Ohm
NEW FaitalPRO 21XL3000 21" Neodymium Subwoofer 8 Ohm
FaitalPROPart # 294-1090
Model: 21XL3000
The FaitalPRO 21XL3000 is a high-performance 21″ neodymium subwoofer driver engineered for professional sound reinforcement where extreme power and deep, impactful bass are required. It combines a robust motor, large dual-layer voice coil, and rigid cone design to deliver controlled low-frequency output with reliability under heavy loads.
  • AES power handling of 3000 W with up to 6000 W peak capability for serious output demands
  • Massive 6.5″ dual-layer voice coil with CCAW winding for efficiency and reduced power compression
  • Neodymium magnet motor with 1.4 T magnetic flux and strong BL factor for high motor force and control
  • Aluminum demodulation ring to minimize inductance variation and lower distortion
  • Ultra-rigid, weather-resistant cone engineered for deep, precise bass reproduction
  • Precision-crafted aluminum basket for mechanical stability and improved thermal dissipation
  • Designed for demanding applications such as touring PA, arenas, clubs, and cinema systems
B&C 21SW152 21" Professional Neodymium Subwoofer 8 Ohm
Price: $982.86Part # 294-6020
NEW $1,786.00
We'll send you an email when FaitalPRO 21XL3000 21" Neodymium Subwoofer 8 Ohm is back in stock or available for preorder.
The FaitalPRO 21XL3000 sets a new benchmark for low frequency performance. Engineered for outstanding power and precision, it is built to meet the needs of the most demanding professional audio systems.
UNLEASH THE POWER
PUMP UP THE VOLUME
The 21XL3000 is engineered for extreme power capacity, rated at 3000 W AES and up to 6000 W program power. Built for outstanding efficiency and long-term reliability, it maintains consistent, high-level output even in the most demanding conditions.
From intense touring rigs and huge festival stages to elite club systems, the 21XL3000 delivers uncompromising performance with deep, forceful bass that is felt just as strongly as it is heard!
SIMPLY
UNSTOPPABLE
A massive VOICE COIL engineered for MAXIMUM PERFORMANCE
At the core of the 21XL3000 is a huge 165 mm (6.5 in) dual-layer voice coil built for maximum efficiency and long-term durability. The dual-layer design enhances overall efficiency, lowers power compression, and supports steady, dependable performance even under extreme demand.
The CCAW (Copper Clad Aluminum Wire) winding structure delivers an ideal mix of conductivity and reduced mass, improving power handling and transient response.
HI-PERFORMANCE
NEODYMIUM MOTOR
The FEA optimized neodymium magnet assembly delivers an outstanding magnetic flux density of 1.4 T, producing a strong BL factor of 43 N/A for excellent motor strength and control. An integrated aluminum demodulation ring reduces inductance changes, lowering distortion and maintaining clean, precise bass reproduction. This design directs more energy into sound instead of heat, supporting consistent, high level performance even in the most demanding applications.
THE CONE
Precision, Depth, Zero Distortion
The 21XL3000 uses an ultra rigid, weatherproof cone engineered to produce deep, powerful bass with precise control. Developed with advanced FEA modeling, the cone structure delivers outstanding stiffness while preserving the responsiveness needed to manage extreme power levels.
The cone features a carefully optimized design that reduces unwanted flex and deformation, supporting precise low frequency reproduction with lower distortion, even at full excursion. The outcome is strong, clearly defined bass that retains clarity and impact, making the 21XL3000 an outstanding option for professional applications where uncompromising sound quality is essential.
STATE OF THE ART
DESIGN
The 21XL3000 is more than a bass powerhouse, it represents advanced design and engineering at its finest. Its newly developed frame features a state of the art design*with bold, modern lines and a commanding visual presence.
In particular, the precision engineered aluminum basket delivers exceptional rigidity and long term durability, maintaining complete stability even under the most demanding operating conditions. Its solid construction improves heat dissipation while supporting precise mechanical alignment, resulting in dependable, consistent performance.
Every element, from the powerful frame styling to the carefully engineered components, showcases a dedication to innovation, performance, and refinement. A true centerpiece product.
*Proprietary registered basket design
Suggested Applications
The 21XL3000 is the ultimate choice for high-end professional audio applications where deep, powerful, and controlled low frequencies are essential. Designed for sound reinforcement in touring sound systems, arenas, high-capacity clubs, large-scale outdoor events, premium cinema or theater installations. This subwoofer delivers exceptional SPL and clarity, even in the most demanding environments. Its superior power handling and efficiency, ensure an immersive, chest-pounding bass experience with uncompromising precision.
BrandFaitalPRO
Model21XL3000
Part Number294-1090
UPC848864082264
Weight52.45
Nominal Diameter21"
Bolt Circle Diameter20.75
Power Handling (RMS)3000 Watts
Power Handling (MAX)6000 Watts
Impedance8Ω
Frequency Response30 to 1500Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter6.5"
Resonant Frequency (Fs)30Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)1.25mH
Mechanical Q (Qms)8.8
Electromagnetic Q (Qes)0.25
Total Q (Qts)0.25
Compliance Equivalent Volume (Vas)10.05ft³
Mechanical Compliance of Suspension (Cms)0.07mm/N
BL Product (BL)43T·m
Diaphragm Mass Inc. Airload (Mms)420g
Maximum Linear Excursion (Xmax)17.67mm
Surface Area of Cone (Sd)1744cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter21.54"
Baffle Cutout Diameter20"
Depth10.16"
