  • FaitalPRO 18HP1022 18" Neodymium Professional Subwoofer 8 Ohm
NEW FaitalPRO 18HP1022 18" Neodymium Professional Subwoofer 8 Ohm
FaitalPROPart # 294-1067
Model: 18HP1022
The FaitalPRO 18HP1022 is an 18″ low‑frequency driver engineered for professional audio systems emphasizing deep bass and high output. Its lightweight neodymium motor and high efficiency design deliver powerful performance while maintaining control.
  • 98 dB sensitivity
  • 1,000 W AES power handling for sustained high output
  • 4″ voice coil mounted on a fiberglass former for improved thermal stability
  • Frequency range from 35 Hz to 1,600 Hz offers deep bass extension
  • Xmax of ±9.5 mm and damage limit of 17.5 mm excursion for heavy duty use
  • Neodymium slug magnet with 1.3 T flux density and aluminum basket for rigidity
  • Made in Italy
NEW $577.00
We'll send you an email when FaitalPRO 18HP1022 18" Neodymium Professional Subwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 4 hr 27 min to ship today. Details
The 18HP1022 combines a 1,000 W AES rating with a high 98 dB sensitivity to deliver strong bass performance without excessive amplifier demands. Its 4″ voice coil on a fiberglass former supports heavy use by effectively managing heat under load. With a frequency range starting at 35 Hz, this driver provides deep extension suitable for serious bass systems. The generous ±9.5 mm Xmax and 17.5 mm damage excursion capability allow the cone to move significant air with control and minimal distortion. The neodymium motor and flux density of 1.3 T provide strong magnetic drive, and the aluminum basket adds mechanical stability to support demanding professional environments.
BrandFaitalPRO
Model18HP1022
Part Number294-1067
UPC848864081694
Weight15.55
Nominal Diameter18"
Bolt Circle Diameter17.32
Frequency Response35 to 1600Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)35Hz
DC Resistance (Re)5.4Ω
Voice Coil Inductance (Le)1.75mH
Mechanical Q (Qms)14.4
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.3
Compliance Equivalent Volume (Vas)7.24ft³
Mechanical Compliance of Suspension (Cms)0.1mm/N
BL Product (BL)28T·m
Diaphragm Mass Inc. Airload (Mms)207g
Maximum Linear Excursion (Xmax)9.5mm
Surface Area of Cone (Sd)1212cm²
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter18.11"
Baffle Cutout Diameter16.61"
Depth7.95"
Sealed Volume20.2ft³
Sealed F3106.2Hz
Vented Volume66.11ft³
Vented F357.04Hz
