  • FaitalPRO 15HP1010 15" Professional Subwoofer 8 Ohm
FaitalPROPart # 294-1064
Model: 15HP1010
The 15HP1010 is a 15″ low‑frequency driver built for professional audio systems where robust power and extended excursion are required. With its 700 W AES rating and 96 dB sensitivity, it offers high‑output performance with efficient amplifier use.
  • 700 W AES power handling for demanding bass reproduction
  • 96 dB sensitivity delivers strong SPL with moderate amplification
  • 4″ (100 mm) copper voice coil on fiberglass former improves thermal endurance
  • Massive ferrite ring magnet (1.05 T flux) provides strong motor force
  • Frequency range 40–2,500 Hz offers deep low‑end and low‑mid coverage
  • Triple‑roll cloth surround and treated polycotton spider for excursion control
  • Made in Italy
Your Price: $429.00
We'll send you an email when FaitalPRO 15HP1010 15" Professional Subwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 5 hr 57 min to ship today. Details
With a 700 W AES rating and efficient 96 dB sensitivity, the 15HP1010 delivers high acoustic output while remaining amp‑friendly. The 4″ voice coil wound on a fiberglass former maintains linear behavior under heavy load and high temperatures. Its ferrite ring magnet structure with 1.05 T flux density sustains motor strength across extended excursions. Covering a 40–2,500 Hz frequency band, the driver bridges deep bass and low‑mid range with clarity. Offering ±9.75 mm Xmax and 21.9 mm peak‑to‑peak excursion, the 15HP1010 handles dynamic content without distortion or mechanical strain. Durable mechanical components including the triple‑roll surround and treated spider provide suspension reliability, making this driver a dependable choice for professional installations and live‑sound systems.
BrandFaitalPRO
Model15HP1010
Part Number294-1064
UPC848864081687
Weight22.2
Nominal Diameter15"
Bolt Circle Diameter14.72
Power Handling (RMS)700 Watts
Power Handling (MAX)1400 Watts
Impedance8Ω
Frequency Response40 to 2500Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)40Hz
DC Resistance (Re)5.3Ω
Voice Coil Inductance (Le)1.8mH
Mechanical Q (Qms)10
Electromagnetic Q (Qes)0.38
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)3.8ft³
Mechanical Compliance of Suspension (Cms)0.11mm/N
BL Product (BL)22T·m
Diaphragm Mass Inc. Airload (Mms)138.9g
Maximum Linear Excursion (Xmax)9.75mm
Surface Area of Cone (Sd)822cm²
Voice Coil FormerFiberglass
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.94"
Depth7.2"
Sealed Volume0.576ft³
Sealed F3100.7Hz
Vented Volume2.24ft³
Vented F349.04Hz
