  • FaitalPRO 12FH520 12" Neodymium Professional Woofer 8 Ohm
FaitalPROPart # 294-1250
Model: 12FH520
The 12" 12FH520 woofer from FaitalPRO is built with cutting-edge features for the best performance possible. Lightweight, high sensitivity and power handling, and great frequency response are hallmarks of the 12FH520.
  • High 98 dB sensitivity
  • Low distortion neodymium motor with an aluminum shorting ring
  • Weighs less than 10 pounds
  • Up to 600 watts of RMS power handling
  • Linear frequency response to 4,000 Hz
  • Made in Italy
Your Price: $441.00
7 In Stock
We'll send you an email when FaitalPRO 12FH520 12" Neodymium Professional Woofer 8 Ohm is back in stock or available for preorder.
Low distortion, high effective bandwidth product (EBP), outstanding sensitivity, and great power handling are hallmarks of FaitalPRO's 12FH520 12" woofer. Add to all of this a lightweight neodymium motor with a built-in aluminum demodulation ring for low distortion, and you have one of the most cutting-edge 12" woofers in the Pro Audio industry.
A treated polycotton triple-roll surround is mated to the 12FH520's treated paper cone for durability, and the 3" aluminum voice coil is mounted on a glass fiber former for maximum heat resistance. The eight-spoke, cast-aluminum frame minimizes backwave reflection while offering maximum structural rigidity. Made in Italy.
BrandFaitalPRO
Model12FH520
Part Number294-1250
UPC848864008363
Weight10.75
Nominal Diameter12"
Bolt Circle Diameter11.75
Power Handling (RMS)600 Watts
Impedance8Ω
Frequency Response50 to 4,000Hz
Sensitivity98dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)50Hz
DC Resistance (Re)5.1Ω
Voice Coil Inductance (Le)0.74mH
Mechanical Q (Qms)11.1
Electromagnetic Q (Qes)0.3
Total Q (Qts)0.29
Compliance Equivalent Volume (Vas)2.27ft³
Mechanical Compliance of Suspension (Cms)0.18mm/N
BL Product (BL)17.3T·m
Diaphragm Mass Inc. Airload (Mms)56g
Maximum Linear Excursion (Xmax)7.25mm
Surface Area of Cone (Sd)500cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter12.44"
Baffle Cutout Diameter11.12"
Depth6.13"
Sealed Volume0.78ft³
Sealed F3142.8Hz
Vented Volume1.75ft³
Vented F357.7Hz
