  • FX-Audio FX202A Class D Audio Amplifier 2 x 53W - Black
BUYOUT FX-Audio FX202A Class D Audio Amplifier 2 x 53W - Black
Factory Buyouts
Part #309-429
Factory Buyouts
Part #309-429
Model: FX202A (black)
The FX-Audio FX202A Class D 2 x 53 watt amplifier produces a powerful output while remaining enclosed in a small footprint. To compensate for various input levels, the FX202A has an adjustable gain switch to match the source. Featuring a rugged build the FX202A's sleek, minimalistic design gives you control over all essential function without overcomplication.
  • Efficient Class D amplification delivers a powerful 2 x 30 watt signal in a small footprint
  • Adjustable gain switch to set the appropriate input level to match the source
  • Features a sleek, minimalistic enclosure that is compact yet rugged
With 53 watts per channel, the FX-Audio FX202A Class D stereo amplifier is a perfect choice for small desktop audio in addition to personal listening setups. The efficient Class D amp topology gives the FX202A a powerful output in a small, compact footprint. Featuring adjustable gain on the bottom of the amp, the FX202A allows you to select the input level to match your source. The rugged build features stereo RCA inputs and high-quality binding posts along with a large volume knob on the front panel that adds to the sleek minimalistic design of the enclosure.
Output power: 2 x 53 watts @ 4 ohms, 2 x 40 watts @ 8 ohms
Frequency response: 20-20,000 Hz
Impedance: 4-8 ohms
Input: Stereo RCA
Outputs: Stereo binding posts
THD: 0.06%
SNR: -96 dB
Gain settings: 32.8, 30, 26.8, 20.8 dB
Chipset: TDA7492PE
DC power supply: 12~24 VDC (24V, 4A power supply included)
Dimensions: 3.8" x 4.7" x 1.3"
BrandFactory Buyouts
ModelFX202A (black)
Part Number309-429
UPC848864059655
Weight1.85
Power (RMS/Channel 8 ohms)51 - 100 Watts
