The FX-Audio DAC-X7 digital to analog converter provides outstanding audio-fidelity for an audiophile level sonic experience. A variety of inputs including optical, coaxial, USB, and AUX give you the ability to connect to a wide array of devices. With a sample rate of up to 32-bit/192 kHz, the DAC-X7 is the ideal DAC for your digital audio system.
High-performance chipsets ensure that the digital to analog conversion of the DAC-X7 is of the greatest audio fidelity. Sample rates of up to 32-bit/384 kHz means that your sonic experience will be clear, crisp, and full. With the USB-B and micro USB connections, you can plug the DAC directly into your PC or phone.
In addition to stereo RCA output the DAC also features 1/4" and 3.5 mm jacks on the front panel. Utilizing an independent headphone amp, the DAC-X7 delivers superb audio fidelity for an all-encompassing, immersive headphone experience. The front panel also features a large volume control as well as input select, and digital display.
• RCA output level: 1.9 Vrms
• RCA output THD: 0.03%
• RCA output SNR: 108 dB
• Headphone output level: 120 mW
• Impedance: 16-300 ohms
• Chipset: XMOS, AK4490EQ, TPA6120, AK4118AEQ, OPA2604
• USB sample rate: 32-bit/384 kHz
• Optical/coaxial sample rate: 24-bit/192 kHz
• DSD: 64/128/256
• Headphone frequency response: 20-20,000 Hz
• Inputs: Optical, coaxial, USB-B, micro USB, 3.5 mm AUX
• Outputs: Stereo RCA, 1/4" headphone, 3.5 mm headphone
• Power supply: 12 VDC, 1A (included)
• Dimensions: 6.6" x 5.1" x 1.2"
