The FX-Audio D502 2.1 digital amplifier produces an uncompromised listening experience perfect for home theaters, listening rooms, and desktop systems. With a variety of both analog and digital input sources, the D502 connects to virtually any input source. In addition to high-fidelity sampling rate, the amplifier also can connect to a PC to be used as a DAC via USB with no software drives required to operate. Dedicated speaker and subwoofer outputs allow you to create a perfectly balanced 2.1 audio setup.
Vast Connection Options
With the D502 you have the option to use both hi-fi digital inputs and conventional analog connections. The D502 offers USB, coaxial, and optical digital inputs with an additional 3.5 mm AUX analog input. Sampling rates up to 24-bit/192 kHz produce audiophile sound quality that retains a crisp, detailed sonic character without unwanted audio artifacts. In addition to source inputs, the D502 can also function as a DAC that will act as your computer's soundcard. The micro USB connection and no need for software drivers makes the amp easy to integrate into any audio system.
High Power 2.1 Amplifier
The D502 has both stereo speaker connections as well as a dedicated output for active subs. A sub out gives you the option to add a subwoofer to complete a great sounding 2.1 audio system.
Note: Remote control not included
• Rated power: 60+60 watts @ 4 ohms, 45+45 watts @ 8 ohms
• Sampling rate: Optical / coaxial 16-24-bit/44.1-192 kHz, USB 16-24-bit/44.1-96 kHz, AUX 24-bit/48 kHz
• Sub output level: 2.7 Vrms
• Frequency response: 10-20,000 Hz
• THD: 0.04%
• SNR: 106 dB
• Inputs: AUX, optical, coaxial, USB
• Outputs: Sub, speaker (L/R)
• Chipset: SA9023+CS8422+TASS5508C+TAS5342A+STM8S103F3-32+PCM1808
• Power supply: 24 VDC, 4A
• Dimensions: 5.23" x 5.11" x 1.45"
