  • F Female to PAL Female Adapter
Part #090-358
Part #090-358
Don't settle for sub-par FM reception by using the manufacturer's cheap FM wire antenna. Connecting your A/V receiver to your outdoor antenna is easy with this PAL female adapter.
  • F female to PAL female for connecting FM antenna to A/V receiver
  • Replace the manufacturer's wire antenna lead
  • Receive clearer FM radio station reception
  • Nickel plated for conductivity and longevity
Your Price: $1.59
MSRP: $1.99
Save $0.40 (20%)
Quantity:Qty: 1-9 $1.59/ea
Quantity:Qty: 10+$1.29/ea
Order in the next 0 hr 10 min to ship today. Details
228In Stock
Audio receiver manufacturers commonly use the male PAL connector for the FM antenna. You will find in the box with your accessories a short wire with a small folded metal contact that pushes over the center conductor of the antenna connector. While this solution may work for some strong local broadcasts, it is less than ideal. Unfortunately, you can't find a way to connect your outdoor antenna to the receiver since the connector is somewhat non-standard.
This PAL adapter connects the receiver's antenna input to a standard male F connector antenna lead. A good outdoor or higher-quality indoor antenna will increase the number of FM radio stations you can receive clearly with a minimum of effort.
Part Number090-358
UPC848864021119
Weight0.0275
