  • F-Conn Gold BNC For Wall Plate System RGB 24-26 Ga. 6 Pcs.
CLEARANCE F-Conn Gold BNC For Wall Plate System RGB 24-26 Ga. 6 Pcs.
F-ConnPart # 092-720
Model: RG1BNCSST
F-Conn's "wall plate" connectors are designed to be used with the new Wall Plate System. Installers now use the same wall plate and insert for every installation, the only difference is the connector that is used.
  • No soldering
  • Full 360 ° compression
  • Can withstand more than 80 pounds of pullout force
  • Radial design reduces impedance problems
  • Internal "O" sealing rings prevent moisture migration
CLEARANCE $9.63
MSRP: $17.26
Save $7.63 (44%)
11 In Stock
We'll send you an email when F-Conn Gold BNC For Wall Plate System RGB 24-26 Ga. 6 Pcs. is back in stock or available for preorder.
F-Conn's "wall plate" connectors are designed to be used with the new Wall Plate System. Installers now use the same wall plate and insert for every installation, the only difference is the connector that is used. The connectors are professional grade that meet the rugged demands of the home and commercial cabling market. They provide true 360° of compression which provide over 80 pounds of pulling force. Internal "O" rings prevent moisture from entering the connector making them perfect for high moisture applications. Only compatible with F-Conn's keystone jacks. Available in BNC, RCA, and "F". Sold in packs of 5. Requires the use of F–Conn compression tool , our part number 092-684.
BrandF-Conn
ModelRG1BNCSST
Part Number092-720
UPC844632058080
Unit of MeasurePackages
Weight0.2001
