  • Eminence Patriot The Copperhead 10" Guitar Speaker 75W 8 Ohm
Eminence SpeakerPart # 290-800
Model: Patriot The Copperhead
Eminence Patriot The Copperhead – Extremely balanced vintage tone with a little country honk and a touch of classic blues tone. • Power handling: 75 watts RMS • Impedance: 8 ohms • Frequency range: 70-5,000 Hz • Sensitivity: 99 dB 1W/1m
  • Application: 10" Open or Closed Back
  • Configuration: 1, 2, or 4 x 10"
  • Coloration: Extremely balanced vintage tone with a little country honk and a touch of blues
  • Genre: Country, Blues, Bluegrass, and Funk
Your Price: $95.99
Save $24.00 (20%)
Only 1 In Stock More due on 12/4/2026
We'll send you an email when Eminence Patriot The Copperhead 10" Guitar Speaker 75W 8 Ohm is back in stock or available for preorder.
Nothing says "American Made" like rock 'n roll or blues. And nothing says "Classic" tone like the Patriot Series of guitar amp speakers from Eminence. Made in the U.S.A. for stand-up volume and reliable, rockin' clarity. The Eminence Copperhead 10" guitar speaker makes a wonderful replacement for the Oxford 12M6-4 guitar speaker found in the '60 - '63 Fender Bandmaster Blonde Guitar Amplifier as well as numerous other guitar speakers found in Fender, Crate, Marshall, Mesa Boogie, Peavey, and Rivera guitar amplifiers. Seven-year manufacturer's warranty.
cop'per head - n. a venomous 10" American guitar speaker, very bright and prone to bite
Specifications: • Power handling: 75 watts RMS • VCdia: 1.5" • Impedance: 8 ohms • Frequency range: 70-5,000 Hz • Sensitivity: 99 dB 1W/1m • Magnet weight: 20 oz. • Dimensions: Overall diameter: 10.11", Cutout diameter: 9.13", Depth: 4.2".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
BrandEminence Speaker
ModelPatriot The Copperhead
Part Number290-800
UPC876358000999
Weight7
Nominal Diameter10"
Power Handling (RMS)75 Watts
Impedance8Ω
