  • Eminence Patriot Red White & Blues 12" Guitar Speaker 120W 8 Ohm
CLEARANCE Eminence Patriot Red White & Blues 12" Guitar Speaker 120W 8 Ohm
Eminence SpeakerPart # 290-814
Model: Patriot Red White & Blues
Eminence Patriot Red White & Blues – A purely American 12" guitar speaker with true-blue mids and highs. • Power handling: 120 watts RMS • Impedance: 8 ohms • Frequency range: 70-4,500 Hz • Sensitivity: 101 dB 1W/1m
  • Application: 12" Open or Closed Back
  • Configuration: 1, 2, or 4 x 12"
  • Nice tight low end, smooth midrange and top end sparkle. American cousin to the Governor.
  • Genre: Classic American Rock tone of the 60's and 70's
CLEARANCE $127.99
Save $32.00 (20%)
Only 1 In Stock
We'll send you an email when Eminence Patriot Red White & Blues 12" Guitar Speaker 120W 8 Ohm is back in stock or available for preorder.
Nothing says "American Made" like rock 'n roll or blues. And nothing says "Classic" tone like the Patriot Series of guitar amp speakers from Eminence. Made in the U.S.A. for stand-up volume and reliable rockin' clarity. Seven-year manufacturer's warranty.
• red, white and blues - n. a purely American 12" guitar speaker with true-blue mids and highs
Specifications: • Power handling: 120 watts RMS • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 70-4,500 Hz • Sensitivity: 101 dB 1W/1m • Magnet weight: 38 oz. • Dimensions: Overall diameter: 12.02", Cutout diameter: 10.97", Depth: 5.1".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
BrandEminence Speaker
ModelPatriot Red White & Blues
Part Number290-814
UPC876358001064
Weight8.9
Nominal Diameter12"
Power Handling (RMS)120 Watts
Impedance8Ω
