  • Eminence Patriot Lil'Buddy 10" Guitar Speaker 50W 8 Ohm
CLEARANCE Eminence Patriot Lil'Buddy 10" Guitar Speaker 50W 8 Ohm
Eminence SpeakerPart # 290-828
Model: Patriot Lil'Buddy
Eminence Patriot Lil'Buddy – A clean and full 10" American guitar speaker with a hemp cone and monster tone. • Power handling: 50 watts RMS • Impedance: 8 ohms • Frequency range: 80-5,000 Hz • Sensitivity: 99.1 dB 1W/1m
  • Coloration: A clean and full tone, slow to break up, but crunchy when driven.
  • Smoother and less defined than many 10" guitar speakers.
  • Genre: Jazz and Blues
We'll send you an email when Eminence Patriot Lil'Buddy 10" Guitar Speaker 50W 8 Ohm is back in stock or available for preorder.
Nothing says "American Made" like rock 'n roll or blues. And nothing says "Classic" tone like the Patriot™ Series of guitar amp speakers from Eminence. Made in the U.S.A. for stand-up volume and reliable rockin' clarity. Seven-year manufacturer's warranty.
lil-buddy - n. a clean and full 10" American guitar speaker with a hemp cone and monster tone
Specifications: • Power handling: 50 watts RMS • VCdia: 1.75" • Impedance: 8 ohms • Frequency range: 80-5,000 Hz • Sensitivity: 99.1 dB 1W/1m • Magnet weight: 30 oz. • Dimensions: Overall diameter: 10.11", Cutout diameter: 9.13", Depth: 4.3".
Electric guitars, guitar amplification, and the birth of Rock-n-Roll in the 1950's collectively established a new use for loudspeakers. Speaker choices were limited in those days and amplifier manufacturers had to purchase products that were common to other applications. Usually, this meant a low-power speaker, often with an Alnico magnet, and limited cone and coil travel.
Due to the nature of the speaker's construction, the sound of the guitar and amplifier combination was impacted by the speaker design. Amplified guitar was a bit more aggressive duty than most other speaker applications at the time and the speakers were frequently challenged in terms of their mechanical movement and linearity. Guitarist learned how to control this non-linearity and use the resulting tonal characteristics to their advantage. Speaker break-up became cool and was a desired feature by most guitarists. The great guitar tones we know now are a result of those events.
Although there are a multitude of distinctive guitar speaker tones available today, they can be broken down into two main categories. We have Marshall and Celestion to thank for the distinctively "British tones" that we are so familiar with. Fender, Peavey, and SLM (Crate/Ampeg) worked with speaker companies like Eminence, Oxford, CTS, JBL, and Electro-Voice to establish tones that are distinctively "American".
Eminence is proud to present the Patriot™ and Red Coat™ series of guitar speakers. Incorporating both British and American cone technology into speakers that are manufactured in the USA gives us the ability to provide you with virtually any tone you desire. Be it British or American, clean or dirty, big bass or screaming highs, we have a speaker that will allow you to "Pick Your Sound".
To help you select the right Eminence guitar speaker, check out Eminence's Tone Guide.
BrandEminence Speaker
ModelPatriot Lil'Buddy
Part Number290-828
UPC876358000647
Weight7.4
Nominal Diameter10"
Power Handling (RMS)50 Watts
