  • Eminence PSD:2013S-8 1" Titanium Compression Horn Driver 8 Ohm 1-3/8"-18 TPI
CLEARANCE Eminence PSD:2013S-8 1" Titanium Compression Horn Driver 8 Ohm 1-3/8"-18 TPI
Eminence SpeakerPart # 290-5600
Model: PSD:2013S-8
Eminence took everything they learned with the popular PSD:2002 and made it better in the PSD:2013S, not only does it have a smoother frequency response and increased high frequency extension, it's improved voice coil design increases power handling. The screw-on design offers quick installation for speaker repairs and speaker upgrades.
  • Great high frequency extension and sensitivity
  • Drop-in upgrade for the PSD:2002
  • 1-3/8"-18 TPI threads
CLEARANCE $139.99
Save $35.00 (20%)
Only 1 In Stock
We'll send you an email when Eminence PSD:2013S-8 1" Titanium Compression Horn Driver 8 Ohm 1-3/8"-18 TPI is back in stock or available for preorder.
Expanding on the success of the popular PSD:2002 model, the 85 watt PSD:2013S features a 1" throat and offers a smoother frequency response through an improved voice coil design, reducing moving mass and increasing high frequency extension. With a sensitivity rating of over 108 dB, the PSD:2013 also features a 2" voice coil, 34 oz. ferrite magnet, a usable frequency range of 1,500 to 20,000 Hz, and 1-3/8"-18 TPI threads to replace high frequency drivers in most professional audio speakers.
Specifications: • Power handling: 85 watts RMS • Impedance: 8 ohms • Frequency range: 1,500-20,000Hz • Sensitivity: 108.3 dB (1W/1m across 1,500 Hz-20 kHz) Magnet weight: 34 oz • Dimensions: 5.25" diameter x 2.3" depth.
BrandEminence Speaker
ModelPSD:2013S-8
Part Number290-5600
UPC876358002207
Weight6.4
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)85 Watts
