  • Eminence N210T 1" Neodymium Compression Driver 8 Ohm
Eminence SpeakerPart # 290-5190
Model: N210T
The Eminence N210T is a high-frequency compression driver renowned for its durability and exceptional audio performance. Some have called it the most copied compression driver of all time. Featuring a 1-inch throat and compact neodymium motor, it's engineered to deliver clear and accurate high-frequency reproduction, making it ideal for professional audio applications.
  • 2-inch voice coil for increased power handling and extended low-frequency response
  • Pure titanium dome with tange-radial ribbed surround for durability and consistent performance
  • Compact neodymium motor for reduced weight without compromising audio quality
  • Fast-On terminal spades for quick and secure installation
  • Rugged die-cast cover for improved heat dissipation and reliability
Your Price: $153.99
Save $38.50 (20%)
We'll send you an email when Eminence N210T 1" Neodymium Compression Driver 8 Ohm is back in stock or available for preorder.
The N210T's titanium dome and radial ribbed surround provide exceptional sound clarity and resilience, making it a trusted choice for professional audio setups. Its lightweight neodymium motor reduces strain on system weight, ensuring effortless integration into various speaker configurations. The Fast-On terminals enhance ease of installation, ensuring secure connections even in demanding environments. With a rugged die-cast cover that aids in heat dissipation, this compression driver ensures long-lasting performance in both live and studio settings. Whether for a concert venue or a high-quality studio monitor, the Eminence N210T-8 combines innovation, durability, and efficiency to deliver unmatched high-frequency audio reproduction.
  • Throat Size: 1", 25.4mm
  • Nominal Impedance: 8Ω
  • Minimum Impedance: 8.6 ohm @ 5.7 kHz
  • Power Rating: 50 W (AES)
  • Resonance: 0.599 kHz
  • Usable Frequency Range: 1.5kHz-20kHz
  • Recommended Crossover: 1.5kHz / 12 dB kHz
  • Sensitivity: 108.5
  • Magnet Material: Neodymium
  • Magnet Weight: 4.16oz, 0.31kg
  • Voice Coil Diameter: 2" / 50.8mm
  • Voice Coil Former: Polyimide
  • Diaphragm Material: Titanium
  • DC Resistance (Re): 6.7 Ω
  • Overall Diameter: 3.85", 97.8mm
  • Driver Volume Displaced: 0.008 cu.ft., 0.22 liters
  • Depth: 1.58", 40.2mm
  • Weight: 1.97 lbs, .89 kg
  • Mounting Thread: N/A
  • Mounting Holes Diameter: 2X 1/4-20
  • Mounting Holes B.C.D.: 3 in. 76.2 mmBolt-on
Frequency Response
BrandEminence Speaker
ModelN210T
Part Number290-5190
UPC876358004744
Weight1.97
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type2-Bolt
Power Handling (RMS)50 Watts
Impedance8Ω
