  • Eminence Legend CA1059 10" Bass Guitar Speaker 8 Ohm
Eminence SpeakerPart # 290-4814
Model: Legend CA1059
Eminence beefed up the popular CA10 bass guitar driver with a larger magnet and improved xmax to create the Legend CA1059. Expect the same classic sound you have come to love, now with better low end and more output capability.
  • Similar sound characteristics to the popular CA10 with more output capabilities
  • Truncated frame allows close driver to driver placement in smaller cabinets
  • 4.7 mm of excursion (9.5 mm peak to peak) can deliver powerful low end kick
  • Rigid cast aluminum frame can withstand the use and abuse of pro sound
Your Price: $163.99
MSRP: $204.99
Save $41.00 (20%)
Only 2 In Stock
We'll send you an email when Eminence Legend CA1059 10" Bass Guitar Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 8 hr 37 min to ship today. Details
A larger magnet version of the popular Legend CA10, the Legend CA1059 is a 10" cast frame bass guitar speaker modeled after the original OEM spec with the punch and clarity that defined the sound of many popular Eden cabinets throughout the decades. Like the CA10, the CA1059's chassis is truncated on the sides for tight fitting in 2x, 4x, and 8x10 configurations. Along with higher Xmax, the CA1059 also features a larger 59 oz. ferrite magnet, producing higher efficiency, and lower Qts for dampening than its smaller magnet version.
Specifications: • Power handling: 250 watts RMS • VCdia: 2" • Impedance: 8 ohms • Frequency range: 50-3,200 Hz • Sensitivity: 98.7 dB 1W/1m • Fs: 48 Hz • Magnet weight: 59 oz. • Dimensions: Overall diameter: 10.5", Cutout diameter: 9.01", Depth: 4.53".
No other speaker is used more widely as standard equipment in guitar and bass guitar amplifiers than Eminence! Most guitar speaker manufacturers are well known for a specific type of tone. Indeed, Eminence is recognized for establishing the "American" rock, country, and blues tones. What really sets Eminence apart though is the ability to provide the guitarist with virtually any tone they desire! Rock, Metal, Country, Blues, British, Rap, Soul, and Alternative styles can be provided with one of the Legend models available. If you're not packing a Legend, you're probably not playing like one!
BrandEminence Speaker
ModelLegend CA1059
Part Number290-4814
UPC876358003921
Weight12.35
Nominal Diameter10"
Power Handling (RMS)250 Watts
