  • Eminence Kappa Pro-10LF 10" Professional Subwoofer 8 Ohm
Eminence SpeakerPart # 290-425
Model: Kappa Pro-10LF
Eminence’s Kappa Pro series reaches a new low with the Kappa Pro 10LF, a low frequency enhanced version of their popular Kappa Pro 10.
  • Large, thoroughly vented magnetic motor
  • Low Fs and high EBP for hornloaded subwoofer enclosures
  • High 600 watt RMS power handling
Your Price: $199.99
MSRP: $249.99
Save $50.00 (20%)
Only 4 In Stock
We'll send you an email when Eminence Kappa Pro-10LF 10" Professional Subwoofer 8 Ohm is back in stock or available for preorder.
Order in the next 6 hr 47 min to ship today. Details
With the low frequency content of modern music demanding more from the low end than in the past, Eminence's Kappa Pro 10LF excels with its high-BL, strong twin-reinforced cone, and high excursion suspension.
Its high power handling capability (600 watts continuous, 1200 watts music program power) and its Thiele-Small parameter set allow it to work in very compact vented or horn loaded bass guitar or subwoofer enclosures.
BrandEminence Speaker
ModelKappa Pro-10LF
Part Number290-425
UPC876358002375
Weight18.3
Nominal Diameter10"
Bolt Circle Diameter9.75
Power Handling (RMS)600 Watts
Frequency Response47 to 2,000Hz
Sensitivity91.6dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)39Hz
DC Resistance (Re)5.47Ω
Voice Coil Inductance (Le)0.97mH
Mechanical Q (Qms)8.97
Electromagnetic Q (Qes)0.29
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)2.58ft³
BL Product (BL)14.46T·m
Diaphragm Mass Inc. Airload (Mms)46g
Maximum Linear Excursion (Xmax)7.2mm
Surface Area of Cone (Sd)376.9cm²
Cone MaterialTreated Paper
Surround MaterialTreated Paper
Overall Outside Diameter10.27"
Baffle Cutout Diameter9.14"
Depth5"
Vented Volume1ft³
Vented F349.3Hz
