  • Eminence ISO-5 5" Midrange/Midbass Isolation Enclosure
Eminence SpeakerPart # 290-5506
Model: ISO-5
The Eminence ISO-5 is a simple solution for isolating any 5" or smaller woofer/midrange driver with an open back. This easy to install reinforced ABS plastic sub-enclosure minimizes resonances while protecting smaller drivers from being pushed around by larger woofers in open enclosure designs.
  • Easily installs on the back of a baffle using 4 screws
  • Includes 5 mm hole for wire access
  • Fits most drivers with a cutout diameter of 4-1/2" or less
  • Thick ABS plastic with reinforcing ribs creates a rigid and lightweight enclosure
Your Price: $14.99
MSRP: $18.74
Save $3.75 (20%)
We'll send you an email when Eminence ISO-5 5" Midrange/Midbass Isolation Enclosure is back in stock or available for preorder.
Order in the next 10 hr 37 min to ship today. Details
The ISO-5 isolation box provides a quick and cost-effective solution for chambering a 5" open frame speaker. The molded ABS construction offers a durable and lightweight option for eliminating interference from larger woofers mounted in the same enclosure. Ideal for any audio application including home, pro, and car audio.
Dimensions:• Overall Diameter: 5-5/16" • Across flats: 4-3/4" • Depth: 3-1/4" • Cutout diameter: 4-1/2".
BrandEminence Speaker
ModelISO-5
Part Number290-5506
UPC876358002849
Weight0.35
