  • Eminence IMPERO 18A 18" High Power Driver Speaker 8 Ohm 1200W
CLEARANCE Eminence IMPERO 18A 18" High Power Driver Speaker 8 Ohm 1200W
Eminence SpeakerPart # 290-696
Model: IMPERO 18A
8 Questions, 16 Answers or
The Eminence Impero 18A 18" 8 ohm pro woofer features a 1,200 watts RMS power rating and a powerful magnet structure that helps this serious transducer move vast volumes of air.
  • Ultra-high power handling capacity guarantees long-term durability
  • 4" diameter copper voice coil on fiberglass former
  • Weather-resistant paper cone and dust cap, treated cloth edge
  • Die cast basket is light yet strong, ready to handle rough travel
  • Massive, optimized motor structure helps move serious volumes of air
  • Capable of sustaining thunderous levels of sub-bass
  • Hand built in the USA
Beyma 18LEX1200Fe LEX Series 18" Subwoofer 8 Ohm
Price: $380.25Part # 253-049
We'll send you an email when Eminence IMPERO 18A 18" High Power Driver Speaker 8 Ohm 1200W is back in stock or available for preorder.
The Eminence Impero 18A 18" high power pro audio speaker is optimized for use in vented enclosures. Its 1,200 watt continuous power rating is a result of Eminence's extensive experience designing and manufacturing loudspeaker drivers for serious professional use.
This 18" cast frame transducer features a 4" diameter copper voice coil that is wound on a fiberglass former. A large magnet, extended and vented pole piece, bumped back plate, and 1/2" thick x 7-1/2" diameter top plate ensure substantial motor strength, resulting in tremendous bass output.
The Impero 18A's performance is ideal for full-range 3-way boxes, bass guitar boxes, and compact to medium-sized subwoofer speaker systems. Recommended enclosure volume: Vented: 113.2 ~ 277.5 liters / 4 ~ 9.8 cu. ft.
BrandEminence Speaker
ModelIMPERO 18A
Part Number290-696
UPC876358002054
Weight31.15
Nominal Diameter18"
Power Handling (RMS)1200 Watts
Power Handling (MAX)2400 Watts
Frequency Response39 to 820Hz
Sensitivity95.9dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)33Hz
DC Resistance (Re)5.41Ω
Voice Coil Inductance (Le)1.47mH
Mechanical Q (Qms)14.02
Electromagnetic Q (Qes)0.44
Total Q (Qts)0.43
Compliance Equivalent Volume (Vas)11.2ft³
Mechanical Compliance of Suspension (Cms)0.17mm/N
BL Product (BL)18.9T·m
Diaphragm Mass Inc. Airload (Mms)140g
Maximum Linear Excursion (Xmax)8mm
Surface Area of Cone (Sd)1159cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter18"
Baffle Cutout Diameter16.56"
Depth8.31"
Sealed Volume4ft³
Sealed F362Hz
Vented Volume8ft³
Vented F338Hz
