  • Eminence DV-77 12" Mick Thompson Signature Series Guitar Speaker 8 Ohm
Eminence SpeakerPart # 290-900
Model: DV-77
Designed by Mike Smith of OMEGA and Mick Thomson of Slipknot, the Eminence DV-77 Signature Series 12" guitar speaker is built for balance, response, and a very musical tone. Delivering tight punchy lows, thick harmonically complex mid-range, and detailed highs without excess fizz, this 8 ohm driver makes Mick's signature tone available to anyone.
  • UK made Kurt Mueller cone to deliver exceptional tone
  • Produces tight punchy lows, complex mid-range, and detailed highs
  • Custom designed basket can handle the difficult touring environment
  • Assembled in the USA for tight tolerances and excellent reliability
Your Price: $164.99
MSRP: $206.24
Save $41.25 (20%)
Only 3 In Stock
We'll send you an email when Eminence DV-77 12" Mick Thompson Signature Series Guitar Speaker 8 Ohm is back in stock or available for preorder.
Build your own custom guitar cabinet with Eminence's DV-77 Mick Thomson Signature 12" guitar speaker. Designed by Mike Smith of OMEGA and Mick Thomson of Slipknot, this driver represents the future of Mick's signature tone. Assembled in the USA by Eminence, the DV-77 leverages a new custom-designed basket, new voice coil design, new spider design, and a carefully chosen UK made Kurt Mueller cone to deliver exceptional tone and reliability. From the beginning, the focus of this speaker was balance, response, and a very musical tone. Delivering tight punchy lows, thick harmonically complex mid-range & detailed highs without excess fizz.
From the beginning, the focus of this speaker was balance, response, and a very musical tonality. Delivering tight punchy lows, thick harmonically complex mid-range & detailed highs without excess fizz. Not a clone or a copy, this speaker was designed in the studio and proven on stage. With over a year of real-world testing by Mick, the DV-77 Mick Thompson Signature Speaker is the perfect addition to your rig.
Overall Specifications: • Nominal diameter: 12" • Power rating: 70 watts • Nominal impedance: 8 ohms • Sensitivity: 100.6 dB • Chassis type: Pressed steel • VCdia: 1.75" • Voice coil material: Copper • Magnet type: Ferrite &bull Frequency range: 70-5,300 Hz • Fs: 70 Hz • DC resistance, Re: 6.47 ohm.
Mounting Information: • Diameter: 12.24" • Overall depth: 5.19" • Cut-out diameter: 11.09" • Number of mounting holes: 8 • Weight: 10.4 lbs.
BrandEminence Speaker
ModelDV-77
Part Number290-900
UPC876358004447
Weight11.6
Nominal Diameter12"
Power Handling (RMS)70 Watts
