  • Eminence APT 80S 80x80 1" Horn Flare 1-3/8"-18 TPI
Eminence SpeakerPart # 290-553
Model: APT 80S
The APT 80S horn flare from Eminence creates 80 degree conical dispersion for 1" screw-on compression drivers.
  • Works with 1" screw-on horn drivers to create focused output
  • Compact size for small PA speakers
  • Durable ABS construction
  • Same horn flare as used on the Eminence APT-80 super tweeter
Your Price: $19.99
MSRP: $24.99
Save $5.00 (20%)
We'll send you an email when Eminence APT 80S 80x80 1" Horn Flare 1-3/8"-18 TPI is back in stock or available for preorder.
Order in the next 14 hr 11 min to ship today. Details
Eminence's APT 80S is built to work with screw-on 1-3/8" 18-TPI compression horn drivers, creating an 80° conical dispersion pattern for focused output. This durable ABS construction wave guide is great for use in compact pro audio speakers, such as stage monitors.
Specifications: • Nominal dispersion: 80° conical • Minimum frequency: 3,000 Hz • Throat diameter: 1" • Overall dimensions: 3.44" H x 3.44" W x 1.62" D • Cutout: 2.94" • Mounting type: 1-3/8"-18 TPI.
BrandEminence Speaker
ModelAPT 80S
Part Number290-553
UPC876358001835
Weight0.1
ConstructionABS
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
