  • Eminence APT-80 Super Tweeter with 80 degree Conical Horn
Eminence SpeakerPart # 290-532
Model: APT-80
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling and controlled low frequency behavior are assured.
  • Smooth response from 3,500 to 20,000 Hz
  • Phenolic diaphragm delivers detailed and accurate sound
  • 80 degree conical dispersion minimizes unwanted reflections
  • Recommended for use with 3,500 Hz or higher crossover
GRS BT2-8 3-3/8" Horn Loaded Bullet Tweeter
Price: $17.99Part # 270-055
PRV Audio WG175Ph Horn Super Tweeter 8 Ohm
Price: $26.91Part # 294-2808
See all items in Horn Loaded Tweeters & Midranges
Your Price: $55.99
MSRP: $69.99
Save $14.00 (20%)
We'll send you an email when Eminence APT-80 Super Tweeter with 80 degree Conical Horn is back in stock or available for preorder.
Order in the next 0 hr 1 min to ship today. Details
The APT high-power super tweeter possesses extraordinary sensitivity thanks to a phenolic diaphragm, which has unique properties of stiffness and damping. By fluid cooling the voice coil, increased power handling, controlled low frequency behavior and long-term reliability are assured. The APT-80 super tweeter is pre-mounted on an 80° conical horn.
Specifications: • Power handling: 45 watts RMS (crossover frequency 3.5 kHz, 18 dB/octave), 85 watts RMS (crossover frequency 5 kHz, 18 dB/octave) • Impedance: 8 ohms • Useable range: 3,500-20,000 Hz • Fs: 2,500 Hz • Recommended crossover: 3,500 Hz • SPL: 102.3 dB 1W/1m • Mfg. #APT-80 • Dimensions: 3-7/16" H x 3-7/16" W x 3-5/8" D • Cutout dimensions: 3-1/8" diameter.
BrandEminence Speaker
ModelAPT-80
Part Number290-532
UPC876358001323
Weight1.6
Diaphragm MaterialPhenolic
Power Handling (RMS)45 Watts
