  • Easy IR Extender Dual Band Target / Receiver 5 ft. Cable
CLEARANCE Easy IR Extender Dual Band Target / Receiver 5 ft. Cable
Parts ExpressPart # 180-643
With Easy IR, it's simple to run IR signals through existing HDMI cables and even through a HDMI distribution system!
  • Easy IR Extender products allow for distributed IR over existing HDMI
  • Quick system connection using HDMI adapters
  • Wide frequency range (30 ~ 60 KHz) for broad compatibility
  • 5' cable length
CLEARANCE $4.49
Save $8.50 (65%)
158 In Stock
We'll send you an email when Easy IR Extender Dual Band Target / Receiver 5 ft. Cable is back in stock or available for preorder.
Order in the next 11 hr 50 min to ship today. Details
The Easy IR Extender system from Parts Express makes distributed IR systems hassle-free by taking advantage of existing HDMI cables, and even distributed HDMI environments (with IR-capable HDMI matrices, splitters, and selectors), using the power and the wiring within the HDMI cable to operate.
This target works with an Easy IR Extender HDMI adapter to insert the Easy IR signal into an HDMI cable. It may then be extracted by another Easy IR HDMI adapter and Easy IR emitter, or passed along through a distributed IR system with any IR-equipped HDMI peripherals. 5' cable length.
Part Number180-643
UPC848864065632
