  • EAS12D123BG 2" X 4-2/4" Full-Range Shielded Speaker 8 Ohm
BUYOUT EAS12D123BG 2" X 4-2/4" Full-Range Shielded Speaker 8 Ohm
Factory BuyoutsPart # 299-4260
Model: EAS12D123BG
The EAS12D123BG 2" X 4-2/4" Full-Range Shielded Speaker utilizes a low-profile race-trace shape making it a perfect choice for small areas.
BUYOUT $1.49
Save $1.49 (50%)
251 In Stock
We'll send you an email when EAS12D123BG 2" X 4-2/4" Full-Range Shielded Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 6 hr 33 min to ship today. Details
The EAS12D123BG 2" X 4-2/4" Full-Range Shielded Speaker utilizes a low-profile race-trace shape making it a perfect choice for small areas. A paper cone, inverted cloth surround and shielded magnet combine for smooth, efficient full-range response from 200 to 15,000 Hz.
BrandCoast Buyouts
ModelEAS12D123BG
Part Number299-4260
UPC848864073750
Weight0.45
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Impedance8Ω
Frequency Response200 to 15,000Hz
Sensitivity86.14dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)237.8Hz
DC Resistance (Re)7.519Ω
Voice Coil Inductance (Le)0.1853mH
Mechanical Q (Qms)5.095
Electromagnetic Q (Qes)3.388
Total Q (Qts)2.035
Compliance Equivalent Volume (Vas)0.02364ft³
Diaphragm Mass Inc. Airload (Mms)1.42g
Maximum Linear Excursion (Xmax)0.5mm
Surface Area of Cone (Sd)40.15cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerPaper
Depth1.75"
