  • EAS1212D131D 3" X 5" Full-Range Speaker 8 Ohm
BUYOUT EAS1212D131D 3" X 5" Full-Range Speaker 8 Ohm
Factory BuyoutsPart # 299-4258
Model: EAS1212D131D
The EAS1212D131D 3" x 5" Speaker uses a paper cone and cloth surround to produce natural full-range response from 150 to 15,000 Hz. Thanks to the powerful shielded motor this driver has excellent efficiency for its size.
BUYOUT $1.44
MSRP: $2.88
Save $1.44 (50%)
1443 In Stock
We'll send you an email when EAS1212D131D 3" X 5" Full-Range Speaker 8 Ohm is back in stock or available for preorder.
Order in the next 3 hr 9 min to ship today. Details
The EAS1212D131D 3" x 5" Speaker has a 5" x 3" mounting flange allowing it to easily fit in slim speaker designs. This driver uses a fully shielded motor for use near devices that are sensitive to stray magnetic fields. This driver can produce an impressive amount of output for its size making it perfect for designs such as speaker bars, TV speakers, and portable Bluetooth enabled projects.
BrandCoast Buyouts
ModelEAS1212D131D
Part Number299-4258
UPC848864073743
Weight0.75
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Frequency Response150 to 15,000Hz
Sensitivity86.88dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)136.9Hz
DC Resistance (Re)6.369Ω
Mechanical Q (Qms)3.998
Electromagnetic Q (Qes)2.001
Total Q (Qts)1.334
Compliance Equivalent Volume (Vas)0.0868ft³
Diaphragm Mass Inc. Airload (Mms)2.317g
Surface Area of Cone (Sd)40.72cm²
Cone MaterialPaper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerPaper
Depth2.25"
