  • Dynamat Vehicle Trim Panel, Head Unit Removal Tool Kit 31-Piece
CLEARANCE Dynamat Vehicle Trim Panel, Head Unit Removal Tool Kit 31-Piece
DynamatPart # 260-599
Model: 10001
Are you tired of struggling to remove stubborn vehicle door panels, locked head units, or other pieces of trim? Look no further than the 31-piece Dynamat kit! This amazing kit can assist you in replacing radios, speakers, or adding damping material with ease.
  • Easily remove vehicle trim, molding, door panels, and head units
  • High quality, heavy-duty plastic tools made with 100% nylon composite for scratch resistance
  • Custom zippered case keeps tools organized
  • Squeeze pop open metal tool when leverage isn't available
  • Multiple metal keys to remove head units from their cages
We'll send you an email when Dynamat Vehicle Trim Panel, Head Unit Removal Tool Kit 31-Piece is back in stock or available for preorder.
With this Dynamat kit, you will have all the necessary tools to tackle even the most difficult trim removal tasks. The kit includes a variety of tools specifically designed to make your job easier and more efficient. From trim removal tools to panel poppers, this kit has it all.
No more struggling with stuck or reluctant door panels. With the help of the Dynamat kit, you'll be able to remove them effortlessly, allowing you to upgrade your speakers or add damping material for improved sound quality. The tools in the kit are specifically engineered to provide the necessary leverage and precision, making the process a breeze.
Locked head units can be a frustrating problem, but fear not! The Dynamat kit comes equipped with tools that will enable you to safely and securely remove them. With the proper tools and techniques, you'll be able to replace your head unit in no time, without causing any damage to your vehicle's interior.
Additionally, if you're looking to add damping material for improved sound insulation, this kit has got you covered. The tools provided will help you remove trim pieces to access the areas where you want to apply the damping material. This will result in a quieter and more comfortable ride, allowing you to enjoy your music without any unwanted noise distractions.
So why continue to struggle with trim removal when you can have the 31-piece Dynamat kit to make your life easier? With its multitude of tools and accessories, this kit is a must-have for any car enthusiast or DIY enthusiast looking to upgrade their audio system or improve their vehicle's sound insulation.
BrandDynamat
Model10001
Part Number260-599
UPC769103100016
Weight2.75
